Smartycam HD 2.1 84° Wide Angle Motocross Video Camara
SKU: SM-CAM-M-HD-2-X99SHD8407
- £775.00
- £775.00
SmartyCam HD 2.1 84° Wide Angle Motorcycle Video Camara
The AiM SmartyCam HD Rev 2.1, 84° Motocross Video Logger Camera is ideal for bike installation where a narrower field of vision (FOV) is needed.
Designed for Motorsports with a single purpose to provide you with great videos that include all the technical information that will help you improve your performance. All this in the most robust and reliable system ever.
Key Features:
SmartyCam HD Rev. 2.1 Competitive Advantages
The video of a whole session once downloaded on your PC can now be split with a simple click in individual videos of each lap: so that you can simultaneously watch two of them and check where you were faster or slower. The same operation can be performed with any SmartyCam HD video recorded on the same track you will be able to compare your best lap with your friends personal best. |
No “wave effect” and Improved Quality with The New CMOS Sensor
Unlike generic multipurpose cameras, SmartyCam HD has been designed to avoid the problem of image distortion, thanks to the innovative Global Shutter CMOS sensor. The camera shutter captures the entire image at the same time, not “pixel by pixel” like traditional sensors. The result is that images are captured at once and are not affected by the vibrations that happen on a racing vehicle, which create the so-called “wave effect”. |
Proprietary Lenses Designed for Motorsports
High Motorsport Quality – Small Size Video Files
Aim SmartyCam ConnectionsSmartyCam can be used with all of our Aim dash display loggers (except Solo 2). With our data hub 4x CAN connection multiplier you can add A GPS Module or extra cameras to your system. See the diagram below: |
AiM SmartyCam HD 84° Track Day Camera
- Video Format: H.264 1280 X 720 pixels @ 30 fps
- Display Resolution: 128 X 128 pixels
- Lens: Telecentric with 6 elements
- Field of View: 67°, 84°
- Internal Battery: Rechargeable Lithium Battery - 1,950mAh
- Battery Charge: 700 mAh 12V
- Internal Battery Duration: 120 - 150 of recording
- External Power: 9 - 15 V
- Supported SD Card: Up to 128 GB
- Memory Capability: 1.5 GB ( 1 hour low quality recording)
- 2 GB ( 1 hour medium quality recording)
- 4 GB. ( 1 hour high quality recording)
- Accelerometer: Three-axial + 5G
- Usage Temperatures: _10°C / +60°C
- Auto Power ON: Yes if connected to the AiM logger
- Auto Power OFF: Yes
- Body: Anodized Aluminium
- Dimensions: 87 x 63 x 49mm
- Bullet Cable Length: 2.0m
- Weight: 280g battery included
MPN: 84° 2m cable - X99SHD8407
MPN: 84° 4m cable - X99SHD8406
- SmartyCam HD Rev 2.1 84°
- Dash or Logger Connection Cable, 2m or 4m (as selected)
- Battery charger
- USB/AC power adaptor
- Software Installation CD
Key Features:
Technical Specifications
Whats in The Box
- Battery charger
