FREE Shipping NEXT DAY Delivery Call +44 (0)1782 393843 Shop now, pay later
Ducati 848, 1098,1198 ECU EVO4S Plug & Play Cable with 7 Pin Male 712 Connector
£50.00
Ducati 848, 1098, 1198 EVO4S Plug & Play Cable
The Ducati ECU Interface cable is a specific cable which allows easy installation and connection of the AiM EVO4S data logger to the bike ECU.
Key Features:
  • ECU Interface Cable
  • Simple Wiring
  • Receive Data
  • 7 Pin
  • 712 Male Connector
  • Free race studio 3 download
Ducati ECU Plug & Play Cable Available For:
  • 848 Base / EVO / EVO Corse - 2007-2013
  • 1098 Base /S/S Tricolore /R - 2007-2009
  • 1198 BASE/S/S Corse/R Corse/SP - 2009-2011
Please Note: If you are unsure this cable will fit your Bike don't hesitate to contact our team. Either by email, phone or our online chat.
Examples of Protocols Below
RPM, Throttle position, Engaged gear, Neutral sensor, Front wheel speed, Rear wheel speed, Engine coolant temperature, Selected map, Engine check, Manual throttle, Intake air temperature, Yawing rate, Rolling rate, Horizontal accelerometer, Vertical accelerometer, Longitudinal acceleration, Traction control intervention, Clutch switch, Side stand, Front brake, Rear brake, Oil pressure switch.
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster.
Unlock your potential
    • Ducati 848, 1098,1198 ECU EVO4S Plug & Play Cable with 7 Pin Male 712 Connector
