FREE Shipping NEXT DAY Delivery Call +44 (0)1782 393843 Shop now, pay later
Ducati 848, 1098 and 1198 Solo 2 DL Plug & Play Cable with 7 Pin Male Connector & Bracket
£85.00
The AiM Ducati 848, 1098, 1198 connector kit males it easy to connect the Solo 2 DL to your bike ECU.
Key Features:
  • Plug & Play interface cable
  • Bracket
  • Receive Data
  • 7 Pin
  • 712 Male Connector
  • Free race studio 3 download
Ducati Solo 2 DL Plug & Play Cable Available For:
  • Ducati 848 Base/EVO/EVO Corse - 2007-2013
  • Ducati 1098 Base/S/S Tricolore/R - 2007-2009
  • Ducati 1198 Base/S/S Corse/R Corse/SP - 2009-2011
Please Note: If you are unsure this cable will fit your Bike don't hesitate to contact our team. Either by email, phone or our online chat.
Our bike specific brackets provide a simple and secure mounting solution for the AiM Solo 2 & Solo 2 DL lap timer.
The brackets are supplied with all the necessary hardware required for fitting to the bike.
If you need help then please check our technical data sheet.
Examples of Protocols Below
RPM, Throttle position, Engaged gear, Neutral sensor, Front wheel speed, Rear wheel speed, Engine coolant temperature, Selected map, Engine check, Manual throttle, Intake air temperature, Yawing rate, Rolling rate, Horizontal accelerometer, Vertical accelerometer, Longitudinal acceleration, Traction control intervention, Clutch switch, Side stand, Front brake, Rear brake, Oil pressure switch.
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster.
Not Enough Check Out Our Solo 2 DL & SmartyCams
Unlock your potential
    • 1 bracket
    • 2 Allen screws with flat head M4x10mm
    • 2 self-locking nuts
    • Ducati Plug & Play Cable
