Ducati Panigale 899, 959,1199,1199R, 1299, V4 Solo 2 DL Plug & Play Cable with 7 Pin Male Connector & Bracket
£85
Ducati Panigale Plug & Play Kit. The Ducati Panigale 899, 959, 1199, 1199 R, 1299, V4 connector kit makes...
The Ducati Panigale 899, 959, 1199, 1199 R, 1299, V4 connector kit makes it easy to connect the Solo 2 DL to your bike ECU.
Key Features:
  • Plug & Play interface cable
  • Bracket
  • Receive Data
  • 7 Pin
  • 712 Male Connector
  • Free race studio 3 download
Ducati Panigale Solo 2 DL Plug & Play Cable Available For:
  • Ducati Panigale - 899 - 2013-2015
  • Ducati Panigale - 959 - from 2016
  • Ducati Panigale - 1199 - 2012-2017
  • Ducati Panigale - 1199 R - 2015-2017
  • Ducati Panigale - 1299 - 2015-2019
  • Ducati Panigale - V4 - from 2018
Examples of Protocols Below
RPM, Throttle position, Engaged gear, Neutral sensor, Front wheel speed, Rear wheel speed, Engine coolant temperature, Selected map, Engine check, Manual throttle, Intake air temperature, Yawing rate, Rolling rate, Horizontal accelerometer, Vertical accelerometer, Longitudinal acceleration, Traction control intervention, Clutch switch, Side stand, Front brake, Rear brake, Oil pressure switch.
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster.
Not Enough Check Out Our Solo 2 DL & SmartyCams
AiM Solo 2 DL Product Video
    • Ducati Panigale Plug & Play Cable
    • 1 Bracket
    • 2 Allen screws with flat head M4x10mm
    • 1 Washer
    • 1 Rubber dowel
    • 1 Allen screw with rounded head M8X45mm
