The Ultimate Track Day Kit for Ducati Panigale.
AiM Solo 2 DL Ducati Panigale Bike kit with SmartyCam Camera, the most precise way to get lap times.
For these Ducati Panigale models:
Key Features:
Aim Solo 2 DL Motorcycle Video Data Logger Track Day Kit, is a powerful data recording combination of the Solo 2 DL and SmartyCam GP HD Bullet Camera.
The GPS technology used in this unit has been updated and now receives the data from three satellite constellations, GPS, Glonass and Galileo; making for a significant improvement in data speed and positioning precision. This means that the start up time is reduced to a matter of seconds and lap times are accurate to a tolerance of two hundredths of a second. |
Solo 2 DL gives instant Speed, Timing, Splits live data and predictive lap times.
Solo 2 DL screen can be back lit in one of seven available colours
The AiM Solo 2 DL has 10 configurable RGB LEDs, and will give you a clear and fast indication of the comparison with your last lap. Predictive page: shows the predicted current lap time in the format you set. |
Solo 2 DL can manage two types of data or races: |
With wifi connectivity you can transfer your data securely and quickly to your laptop or computer without cables. |
AiM Solo 2 DL
- Display: Graphical
- Display resolution:238x99 pixels
- Display pages: Up to 8 freely configurable
- Back light: 7 configurable RGB colours
- Shift lights/alarm LED's :10 configurable RGB LED's
- Integrated track database:Yes
- Inertial platform: Internal 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
- GPS: 10 Hz External power:12 V
- Memory: 4 GB
- Dimensions: 98.0x73.7x30.2 mm
- Weight: 240 g, battery included
- ECU Connection: CAN,RS232 or K-Line to 1,000+ industry leading ECUs
- Multiple Configuration Management: Yes
- Aim Solo DL 2 DL Motorcycle Lap Timer
- Power cable with AC adapter
- User manual
- Aim sticker
- SmartyCam GP HD Rev .2.2 Bullet-Cam
- 2m Cable
- UK Adapter
- Camera Bracket
- Power Lead
- Ducati Panigale V4, 899, 959, 1199, 1199 R, 1299 Connection Cable
- Ducati Panigale Bracket
