Ducati Panigale V2 Solo 2 DL Plug & Play Cable
The Ducati Panigale ECU Interface cable is a specific cable which allows easy installation and connecting to an AiM Solo 2 DL lap timer or EVO4S data logger.
Key Features:
Please Note: If you are unsure this cable will fit your Bike don't hesitate to contact our team. Either by email, phone or our online chat. |
The connection point for this cable is at the nose of the bike. If your bike doesn't have GPS, use the blanking port in the mating connector. If your bike does have GPS then put the connector between the two.
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster. |
Not Enough Check Out Our Solo 2 DL & SmartyCams |
Unlock your potential |
Ducati Panigale V2 Solo 2 DL Plug & Play Cable with 7 Pin Male 712 Connector
- Ducati Panigale V2 Solo 2 DL Plug & Play Cable with 7 Pin Male 712 Connector
