Evo 5 Harness 22 Pin Harness
£260
EVO 5 Harness 22 Pin Harness. The EVO 5 22 pin harness is for use with the EVO...
The EVO 5 22 pin harness is for use with the EVO 5 data logger.
Key Features:
  • Up to 4 analog sensors
  • Simple Wiring
  • Receive Data
  • Free Race Studio 3 Download
EVO 5 22 Pin Harness
This 22 pin harness will allow up to 4 analog sensors/channels. You may require data on Water temperature, Oil temperature ,Oil pressure or Brake pressure.
The 22 pin harness will provided access to the following functions:
Analog sensor channels 5,6,7,8
Digital wheel speed sensor inputs 2,3,4
Digital 12v outputs 1,2
RS232 ECU connection
CAN 2 ECU connection
Not Enough Check Out Our EVO 5 & SmartyCams
AiM Product Video
    • EVO 5 22 Pin Harness
