Honda 600 CBR-RR / 1000 CBR-RR Solo 2 DL Plug & Play Cable with 7 Pin Male Connector & Bracket
£85
Honda 600 CBR-RR / 1000 CBR-RR Connector Kit. The AiM Honda CBR 600-RR & 1000-RR connector kit makes...
The AiM Honda CBR 600-RR & 1000-RR connector kit makes it easy to connect the Solo 2 DL to your bike ECU.
Key Features:
  • Plug & Play interface cable
  • Bracket
  • Receive Data
  • 7 Pin
  • 712 Male Connector
  • Free race studio 3 download
Honda Solo 2 DL Plug & Play Cable Available For:
  • Honda CBR - 600 RR - 2003 - 2019
  • Honda CBR - 600 RR HRC with D11 marked ECU - 2013-2015
  • Honda CBR - 1000 RR - 2004-2016
  • Honda CBR - 1000 RR HRC - 2014-2016
Examples of Protocols Below
RPM, Throttle position, Engaged gear, Neutral sensor, Front wheel speed, Rear wheel speed, Engine coolant temperature, Selected map, Engine check, Manual throttle, Intake air temperature, Yawing rate, Rolling rate, Horizontal accelerometer, Vertical accelerometer, Longitudinal acceleration, Traction control intervention, Clutch switch, Side stand, Front brake, Rear brake, Oil pressure switch.
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster.
Not Enough Check Out Our Solo 2 DL & SmartyCams
    • Honda Plug & Play Cable
    • 1 Bracket
    • 2 Allen screws with flat head M4X10MM
    • 1 washer
    • 1 Allen screw with rounded head M6X60
    • 1 rubber dowel
