Honda CBR 600RR & 1000RR SOLO 2 DL Plug & Play Kit
£500
The Honda CBR 600RR & 1000RR SOLO 2 DL Plug & Play Kit allows easy connection to the...
The Honda CBR 600RR & 1000RR SOLO 2 DL Plug & Play Kit allows easy connection to the Solo 2 DL to your bike ECU.
Crank up your performance with our plug and play Solo 2 DL connection kit for the Honda 600RR and 1000RR bikes.
Use the Solo 2 DL’s data logging features to display and collect your bike’s ECU parameters – such as GPS speed, air temperature, throttle position, manifold air pressure and much more. Perfect for both track days and the open road, the device can be hooked up to your Honda bike with a single cable (DLC connector found under the seat) and the bracket provided.
At the end of your driving stint, you can analyse your performance by uploading the data to Race Studio 3 (WiFi) to gain a competitive advantage.
The kit includes an ECU connection cable (DLC connector), mounting bracket and fittings for straightforward and easy installation.
The kit is compatible with:
  • Honda CBR 600RR 2003 - 2019
  • Honda CBR 600RR HRC with D11 marked ECU 2013 - 2015
  • Honda CBR 1000RR 2004 - 2016
  • Honda CBR 1000RR HRC 2014 - 2016
What’s more, the Solo 2 DL provides you with plenty of other features:
  • Real-time data: GPS speed, delta, lap number, etc.
  • Compare your current lap with the best in session.
  • Use the LEDs to display RPM or shift lights.
  • Performance mode: select between point to point events and track racing.
  • Available port to connect the Smartycam or EVO4s.
  • Integrated Wi-Fi for quick transfer of data to laptop or computer.
  • Always see the information on the screen with the available 7 LED display colours.
  • Database of over 3000 tracks pre-configured on device.
  • The most precise GPS technology for ultimate accuracy.
  • Race Studio 3 is included in the package for advanced driving analysis.
List of available ECU channels configurable with Honda HDS_TAB10 protocol:
RPM
Throttle position sensor voltage
Water temperature
Intake air temperature
Manifold air pressure
Battery voltage
Vehicle speed
Ignition angle advance
Injection time (milliseconds)
List of available ECU channels configurable with Honda HDS_TAB11 protocol:
RPM
Water temperature
Battery voltage
Vehicle speed
Free channel to be assigned
    • Display: Graphical
    • Display resolution:128x64 pixels
    • Display pages: Up to 8 freely configurable
    • Back light:7 configurable RGB colours
    • Shift lights/alarm LEDs:10 configurable RGB LED's
    • Integrated track database:Yes
    • Inertial platform:Internal 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
    • Wi-Fi connection: Yes
    • GPS: 10 Hz External power:12 V
    • Memory: 4 GB
    • Pushbuttons: Metallic
    • Dimensions: 98.0x73.7x30.2 mm
    • Weight: 240 g, battery included
    Solo DL 2  Motorcycle ECU connection: CAN, RS232 or K-Line to 1,000 + industry leading ECUs
    Solo 2 Front View SOLO-2-Rear-View SOLO-2-Side-View
    • Aim Solo 2 DL GPS Lap Timer
    • Honda Ecu and power connection lead
    • Honda mounting bracket kit
    • User manual
    • Software installation CD
    • AIM sticker
    Honda CBR 600RR & 1000RR in the box
