HONDA CBR 600RR BBR 1000RR SOLO 2 DL Plug & Play Kit – AimShop.com
SKU: SOLO2-K-HON
Availability: 30 in stock
£600.00
QTY:
Trust Badge
The HONDA CBR 600RR BBR 1000RR SOLO 2 DL Plug & Play Kit is a completely automatic motorcycle lap timer that receives the data from two satellite constellations GPS and Glonass, which is a huge step forward since it is unbelievably faster and more precise than the previous version.
Designed to connect to the following Honda models;
  • CBR 1000RR 2004-2015
    CBR 1000RR HRC 2014-2015
    CBR 600RR HRC with ECU marked D11 2013-2015
The kit includes a ECU connection lead and mounting bracket kit.
 Solo 2 DL, with ECU Connection
The power ON requires only a few seconds and the lap times are calculated with a max 2/100 sec of tolerance.
“the most precise and easy way to get lap times”
Aim SOLO 2 GPS Lap Timer
Aim HONDA CBR Plug & Play Kit screen can be backlit in one of the seven available colors:
Aim Solo 2 Back Light Colours
Find Your Track Easily and Quickly
Find your track easily and quickly
HONDA CBR can rely on a database of more than 3,000 tracks all over the world: as soon as it switches on, Solo 2 identifies its position, recognises the starting line coordinates of the track and starts sampling lap times. In the event that the track is not in the database then no problem. Solo 2 realises it and enters into the auto learning mode, automatically understands the characteristics of the track and gives the lap time anyway.
Even the Predictive Lap Time is Much More Reliable
The Aim Solo 2 configurable RGB LEDs,
The HONDA CBR Plug & Play Data Logger Kit is configurable RGB LEDs, will give you a clear and fast indication of the comparison with your best lap.
Solo 2 Race Mode Selection
Solo 2 can manage different types of races, Speed races in a closed circuit
Solo 2 DL can manage different types of races, Speed races in a closed circuit, Point to-point races, Regularity, Performance tests (0-100 km/h etc.) In each of these configurations, Solo 2 DL gives you the correct information during the test and powerful data review immediately after each session.
Solo 2 Race Data Recall on Screen
At the end of your test, you can quickly review all the key information on your display.
Solo 2 DL Wi-Fi Communication with the PC
Solo 2 Wi-Fi Communication with the PC
Wi-Fi connection is easy and fast without connectors or cables, Simply the best way to configure your Solo 2 DL, to manage the track database and to download the data to your PC.
iPhone Connection COMING SOON!
iPhone Connection
Use your iPhone for a quick and comfortable  data analysis, for managing the track database and even for an On-Line view of the most important parameters of your Engine.
SmartyCam HD Connection
SmartyCam HD and Solo 2 Connection
HONDA CBR Plug & Play Data Logger Kit - The perfect connection
Get all the data from your ECU, merge them with the GPS information and transmit everything to the SmartyCam HD, that will show them in graphical overlay in the video.
Solo 2 - The perfect connection
In The Box
  • HONDA CBR 600RR BBR 1000RR SOLO 2 DL Plug & Play Kit
  • ECU connection Lead
  • Bracket and screws
  • User manual
  • Software installation CD
  • Aim sticker
    • Display: Graphical
    • Display resolution:128x64 pixels
    • Display pages: Up to 8 freely configurable
    • Back light:7 configurable RGB colors
    • Shift lights/alarm LEDs:10 configurable RGB LEDs
    • Integrated track database:Yes
    • Inertial platform:Internal 3 axis ±5G accelerometer + 3 axis gyro + 3 axis magnetometer
    • Wi-Fi connection: Yes
    • GPS: 10 Hz External power:12 V
    • Memory: 4 GB
    • Pushbuttons: Metallic
    • Dimensions: 98.0x73.7x30.2 mm
    • Weight: 240 g, battery included
    Solo 2 Front View SOLO-2-Rear-View SOLO-2-Side-View
