Honda CBR ECU EVO4S Plug & Play Cable.
The Honda ECU Interface cable is a specific cable which allows easy installation and connection of the AiM EVO4S data logger to the bike ECU.
Key Features:
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster. |
Not Enough Check Out Our Solo 2 DL & SmartyCams |
Honda CBR 600RR / CBR 1000RR ECU EVO4S Plug & Play Cable with 7 Pin Male 712 Connector
- Honda CBR 600RR / CBR 1000RR ECU EVO4S Plug & Play Cable with 7 Pin Male 712 Connector
