Hub For Universal Steering Wheel Bracket – Aim Shop - Motorsport Data Loggers, Displays and Laptimers
SKU: UP-CH
Availability: 19 in stock
£12.00
QTY:
Trust Badge
Hub For Universal Steering Wheel Mounts.
This is the centre hub to use if you only want to mount a dash on the steering column side of your quick release.
Facilitates the use of one of our dash/display/phone mounts.
  • 70 & 76mm PCD 6 hole fitting covers almost all 6 bolt steering wheels.
  • 2mm thick in Raw Stainless Steel
Our interchangeable stainless steel steering wheel button and display mounts are a very stylish and cost effective solution to your mounting requirements. The whole design is based around the centre hub which mounts between your steering wheel and (usually) your quick release device.
**Please note that if you have a low or no 'dish' steering wheel, you will probably need the 3mm hub spacer to give sufficient bolt head clearance**
