Infrared Tyre Temperature Sensor – AimShop.com
SKU: S-T-IR
Availability: 48 in stock
£102.00
QTY:
Trust Badge
Infrared Tyre Temperature Sensor for car.  Aim loggers can measure tyre temperature connecting to one or more temperature sensors directly connected to the measure points. The sensor is sold with a 25 cm cable and standard lengths extension cables are available as optional; it is also possible to ask for specific length extension cables.
Sensor part number is: X05TTS01B0
Installation and connection
Use a self-built bracket to install the sensor; place it far from strong heat sources (the exhaust pipe for instance) and from electromagnetic interference sources. The best installation point is the internal part of the fender so to avoid that the sensor get damaged bouncing stones or other stuff.
Dimensions, pinout and technical characteristics
The drawing here below shows the sensor dimensions in millimetres [inches]
sensor technical
The sensor technical characteristics:
  • Output signal: 0-5V
  • Field of measure: 35°
  • Working range: -20/120°C
  • Sensor electrical range:
  • 820 Mv/-20°C
  • 3230 Mv/120°C
  • Sensor dimensions: 26.6x17.2 mm
  • Sensor cable length: 250 mm
Extension cables part numbers change according to their length and to the device the sensor is to be connected to.
Extension cable for connection with:
  • EVO4
  • EVO4
  • Channel Expansion
  • MyChron Expansion
Part numbers:
V02PCB05BTXG – cable length: 500 mm
V02PCB10BTXG – cable length: 1000 mm
V02PCB15BTXG – cable length: 1500 mm
V02PCB20BTXG – cable length: 2000 mm
V02PCB25BTXG – cable length: 2500 mm
V02PCB30BTXG – cable length: 3000 mm
Mandatory extension cable
  • MXG
  • MXS
  • MXL2
  • EVO5
  • MXL/Pista/Pro05
Extensiob Cable
Part numbers:
V02PCB05B – cable length: 500mm
V02PCB10B – cable length: 1000mm
V02PCB15B – cable length: 1500mm
V02PCB20B – cable length: 2000mm
V02PCB25B – cable length: 2500mm
V02PCB30B – cable length: 3000mm
