Kawasaki ZX-10R ECU EVO4S Plug & Play Cable with 7 Pin Male 712 Connector
£50
Kawasaki ZX-10R ECU EVO4S Plug & Play Cable. The Kawaski ECU Interface cable is a specific cable which allows easy installation...
The Kawaski ECU Interface cable is a specific cable which allows easy installation and connection of the AiM EVO4S data logger to the bike ECU.
Key Features:
  • ECU Interface Cable
  • Simple Wiring
  • Receive Data
  • 7 Pin
  • 712 Male Conntor
  • Free race studio 3 download
Kawasaki ECU Plug & Play Cable Available For:
  • Kawasaki Ninja ZX-10R MY2011 - 2011-2015
  • Kawasaki Ninja ZX-10R MY2011 Racing Kit - 2011-2015
  • Kawasaki Ninja ZX-10R MY2016 - from 2016
  • Kawasaki Ninja ZX-10R MY2016 Racing Kit - from 2016
Examples of Protocols Below
RPM, Throttle position, Engaged gear, Neutral sensor, Front wheel speed, Rear wheel speed, Engine coolant temperature, Selected map, Engine check, Manual throttle, Intake air temperature, Yawing rate, Rolling rate, Horizontal accelerometer, Vertical accelerometer, Longitudinal acceleration, Traction control intervention, Clutch switch, Side stand, Front brake, Rear brake, Oil pressure switch.
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster.
Not Enough Check Out Our Solo 2 DL & SmartyCams
    • Kawasaki ZX-10R ECU EVO4S Plug & Play Cable with 7 Pin Male 712 Connector
