Life Racing F88GDI4L ECU Direct Injection Engine Management System
£1,950.00
The new F88GDI4L ECU sets the benchmark for integrated direct injection engine management. Based on the F88 architecture with the F88GDI4L, there is no means of compromise. The F88GDI4L control unit features efficient use of I/O complement specifically designed for modern engines up to 4-cylinders yet cost-effective for GDI and CI applications.
The F88GDI4L is designed to drive all solenoid Direct Injection (DI) injectors, including all production parts from Ford, GM, Siemens, Hitachi and Bosch (including Bosch Motorsport types) without the need for an external driver module.
4 dedicated GDI injector drive outputs 24 user configuration general-purpose analogue sensor inputs
24 user configuration general-purpose pulse width modulated power outputs Powerful RISC CPU for advanced strategy execution
Custom synchronous co-procrssor for engine position tracking up to 25,000rpm 64MB internal logging memory
The new F88GDI4L ECU sets the benchmark for integrated direct injection engine management. Based on the F88 architecture with the F88GDI4L, there is no means of compromise. The F88GDI4L control unit features efficient use of I/O complement specifically designed for modern engines up to 4-cylinders yet cost-effective for GDI and CI applications that do not require the complexity of the F90 series controllers.
The twin processor F88GDI4L uses a high-speed RISC processor for code execution and an additional sizeable co-processing logic array for high speed, precision accuracy engine position tracking. This powerful combination also allows advanced control algorithms whilst remaining easy to calibrate.
The F88GDI4L is designed to drive all solenoid Direct Injection (DI) injectors, including all production parts from Ford, GM, Siemens, Hitachi and Bosch (including Bosch Motorsport types) without the need for an external driver module. Standard strategies accommodate the following engines and functions:- Normally Aspirated, Turbocharged, Supercharged, Drive-by-Wire (DBW), Knock Control, Traction Control (TC), Anti-Lag System (ALS), Twin-Cam VVT, VTec, GearCut and GearBlip, Differential control plus other known engines/transmission facilities. In addition, the internal data-logging coupled with a unique crank and cam sync-logger allows detailed review of input, control signals to make fault diagnosis simple and effective.
The twin processor F88GDI4L uses a high-speed RISC processor for code execution and an additional large co-processing logic array for high speed, precision accuracy engine position tracking. This powerful combination also allows advanced control algorithms whilst remaining easy to calibrate.
The F88GDI4L is designed to drive all solenoid Direct Injection (DI) injectors, including all production parts from Ford, GM, Siemens, Hitachi and Bosch (including Bosch Motorsport types) without the need for an external driver module. Standard strategies accommodate the following engines and functions:- Normally Aspirated, Turbocharged, Supercharged, Drive-by-Wire (DBW), Knock Control, Traction Control (TC), Anti-Lag System (ALS), Twin-Cam VVT, VTec, GearCut and GearBlip, Differential control plus other known engines / transmission facilities. In addition, the internal data-logging coupled with a unique crank and cam sync-logger allows detailed review of input, control signals to make fault diagnosis simple and effective.
The new and powerful F88GDI4L hardware is packaged within a lightweight high-pressure die-cast Aluminium case designed for harsh production and motorsport automotive environments.
Processing
Custom synchronous co-processor for engine position tracking up to 25,000rpm
Outputs
24 User configurable general-purpose Pulse Width Modulated power outputs, including:
4 Ignition coil outputs IGBT or TTL (Software configurable)
10 General PWM/Port injector outputs
2 Inductive load/general PWM outputs
4 Dedicated GDI injector drive outputs (Software configurable power settings)
3 Full-bridges also configurable a six half-bridges or 6 PWMs
Inputs
24 User configurable general-purpose analogue sensor inputs, including 16 bipolar, inductive or hall effect speed/engine position inputs
3 Dedicated inputs, including:
Two Acoustic knock sensor inputs
1 Wideband (NTK) UEGO Lambda sensor interface (low cost and precision sensors available)
Interfaces
100 MHz full-duplex Ethernet for calibration, configuration and data download
3 CAN 2.0B interfaces for communication with other controllers or logging systems
Memory
64MB battery-backed internal logging memory
Ultra-Fast data download via Ethernet
Time/Date stamped data via real-time clock
Power Supply
6 to 32V input voltage range with reverse polarity protection
Two regulated 5V sensor supply output with individual short circuit protection
Five separately protected sensor and communication ground inputs
Physical
88 Way Bosch / AMP sealed connector
Sealed high-pressure die-cast black powder-coated aluminium case
The maximum dimension including the connector is 183mm x 125mm x 36mm
Operating temperature -40C to +50°C
The total mass is 520 grams
  • Processing:
  • Powerful RISC CPU for advanced strategy execution
  • Custom synchronous co-processor for engine position tracking up to 25,000rpm
  • Outputs:
  • 24 User configurable general-purpose Pulse Width Modulated power outputs, including
  • 4 Ignition coil outputs IGBT or TTL (Software configurable)
  • 10 General PWM/Port injector outputs
  • 2 Inductive load/general PWM outputs
  • 4 Dedicated GDI injector drive outputs (Software configurable power settings)
  • 3 Full-bridges also configurable as six half-bridges or 6 PWMs
  • Inputs:
  • 24 User configurable general-purpose analogue sensor inputs, including 16 bipolar, inductive or hall effect speed/engine position inputs
  • 3 Dedicated inputs, including
  • 2 Acoustic knock sensor inputs
  • 1 Wideband (NTK) UEGO Lambda sensor interface (low cost and precision sensors available)
  • Interfaces:
  • 100MHz Full-duplex Ethernet for calibration, configuration, and data download
  • 2 CAN 2.0B Interfaces for communication with other controllers or logging systems
  • Memory:
  • 64MB Internal logging memory
  • Ultra-Fast data download via Ethernet
  • Time/Date stamped data via real-time clock
  • Power Supply:
  • 6V to 30V Input voltage range with reverse polarity protection
  • 2 Regulated 5V sensor supply outputs with individual short circuit protection
  • 5 Separately protected sensor and communication ground input.
  • Physical:
  • 88-way Bosch / AMP sealed connector
  • Sealed, high-pressure diecast black powder-coated aluminium case
  • The maximum dimension including the connector is 183mm x 125mm x 36mm
  • Operating temperature -40C to +85°C
  • Total mass 520 grams
  • Warranty & Servicing:
  • This equipment comes with a 1-year warranty against manufacturing defects and failures; however, misuse or damage will not be covered under warranty.
  • Warranty may be extended on an annual basis via a system refurbishment scheme.
  • This ECU contains a battery that can be returned to Life Racing for a replacement. A charge may be made for this service.
  • Life Racing F88GDI4L ECU
