Motorsport Car Throttle Sensor and Cable – Aim Shop - Motorsport Data Loggers, Displays and Laptimers
SKU: CSS-T-C-1
Availability: 49 in stock
£114.00
QTY:
Trust Badge
The Motorsport Car Throttle Sensor and Cable is a Professional engineers quality motorsport sensor designed for the rigours of motorsport
Aim motorsport Throttle Sensor - Aim instruments can measure the relative displacement between two different points using a sensor (rotary potentiometer) directly connected to the two measure points. This sensor may be used to measure angular displacements, such as throttle position.
Aim Technologies are committed to supplying, professional engineers quality motorsport sensor products. These small, lightweight but well-engineered pressure sensors, are amongst the best in the market place today
Aim motorsport sensors are IP67, and weight only 34grams, made from stainless steel, and operate between -20C and +135 C
The Aim motorsport series of pressure transducers have been designed for the detection of fluid and air pressures in demanding motorsport and automotive applications.
ORDER NOW FOR
FREE DELIVERY ON THIS PRODUCT
Installation notes
The sensor has been designed to measure rotational displacements between a fixed point, called “reference point”, and a movable one.
The first installation step consists in fixing the potentiometer to the chassis using two M3 screws or a self-made iron bracket. Once the sensor mounted on your vehicle, you can connect the rotating cursor to the throttle or to the pedal or to other moving elements.
Please ensure that when the throttle is in its “zero position” (i.e. when the throttle is not pressed), the potentiometer is in its “zero position” too and when the throttle is completely pressed, the potentiometer is in its “high” position.
This instrument’s mechanical measure range goes up to 130°, while the electrical measure range goes up to 106°. Please, do not exceed the instrument maximum measure range. If you need to measure bigger displacements, please use a different sensor: an incorrect use may seriously damage the sensor.
