MV Agusta Solo 2 DL Plug & Play Cable.
The MV Agusta ECU Interface cable is a specific cable which allows easy installation and connecting to an AiM Solo 2 DL lap timer or EVO4S data logger.
Key Features:
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster. |
Not Enough Check Out Our Solo 2 DL & SmartyCams |
MV Agusta F3 675, F3 800, F4 1000 Solo 2 DL Plug & Play Cable with 7 Pin Male 712 Connector
- MV Agusta F3 675, F3 800, F4 1000 Solo 2 DL Plug & Play Cable with 7 Pin Male 712 Connector
