MXP BMW Logger with CAN Connection
AiM MXP Dash Logger features a 6" wide colour TFT display, offering a great visual impact.
Key Features:
MXP can define all the custom pages you want. The MXP shows together with RPM scale. All the data you need like speed, water temperature, oil pressure and much more. You can choose the custom pages you want, with four additional fields from a wide library of page styles. Which define which data you want to be shown with end scale and measuring units. You can swop between pages using the push buttons. |
The 10 multi-coloured RGB shift lights can be customised to how you want them, defining the RPM threshold for each single gear. The same flexibility applies to the configurable RGB alarms LEDs, you can configure them in order to turn them on / off depending on analogue or digital inputs, ECU values, expansion values, math channels or GPS information. You choose the conditions and colours. Select a solid alarm or a flashing one, also the flashing frequency. It is also possible to configure an accompany text message on the display and set the alarm priorities. |
CAN Output & Digital Output |
With the CAN Output you can send messages directly to an existing CAN network in order to improve the range of vehicle control possibilities. MXP features two digital outputs. These LOW SIDE type (switch to ground): can be configured in order to be activated/deactivated depending on the value of the analogue/digital inputs. This allows you to automatically run external systems, i.e. to switch on/off additional lights or to activate/de-activate a cooling fan or circulation pumps etc when a certain event happens. |
Wi-Fi Connectivity
MXP Connection Examples |
Unlock your potential |
AiM MXP 6" TFT Display Dash Data Logger
- Display: 6" TFT
- Resolution: 800x480 pixels
- Contrast: 600:1
- Ambient light sensor: Yes
- Alarm display icons: Yes, freely configurable
- Shift lights: 10 configurable RGB LEDs
- CAN connections: 3
- ECU connections: CAN, RS232, K-Line
- ECU compatibility: 1,000 + industry leading ECUs
- Expansion CAN connection: GPS Module, Channel expansion, TC hub, lambda controller, Smartycam HD
- Analog inputs: 8 fully configurable, max 1,000 Hz each
- Digital inputs: 4 speed inputs, lap signal, coil RPM input
- Digital outputs: 2 ( 1 A max each)
- Second CAN: Yes
- Internal platform: Internal 3 axis +5G accelerometer + 3 axis gyro + 3 axis magnetometer
- Internal memory: 4 GB
- Body: Aluminium
- Connectors: 2 Motorsport + 1 Binder connector
- Power consumption: 400 mA
- Weight: 640g
- MXP Dash Display
- 37 pins standard harness
- GPS08 Module
- USB Cable
- AIM Sticker
