Free Shipping Next Day Delivery +44 (0)1782 393843 Shop now, Pay Later
MXP Strada Yamaha IVA Compliant 6" TFT Display Plug & Play Kit
£850.00
The road legal - MOT approved, IVA compliant digital dash display, is a complete road legal display solution.
Key Features:
  • 6" TFT display
  • Road legal, MOT approved
  • CAN output
  • ECU connection
  • Wheel speed sensor
  • Simple connection harness
Please Note: Don't forget to check out the optional extras at the top of this page where you will find the GPS Module with a length of cables to fit your requirements, a reversing / mirror camera with different patch lead lengths and many more items to help with your build.
The AiM MXP 1.2 Strada IVA Compliant dash kit has a 6" colour TFT display. And is one of the most widely used dashes on road and tracks all over the world. It has an exceptional visual impact and configurable to show all the information coming from the Engine Control Unit (ECU), analogue / digital inputs, pre-defined math channels and the optional GPS Module.
Connecting the MXP Strada IVA dash to your motorcycle ECU is very simple. Sample and display dozens of channels straight from the vehicle’s ECU. This is often the quickest and easiest setup, needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors. As well as the standard 14 pin wiring loom, this kit comes with an additional 23 pin loom which has pre-configured connections for all the relevant electrical items of your vehicle such as oil temperature, engine temperature, fuel level, side lights, hazards, front and rear fog, handbrake, main beam, dipped beam and left and right hand indicator. A speed sensor is also included, for connecting to this additional loom.
High Contrast TFT Display: The MXP Strada has a high contrast 6" TFT display. Its visual quality being always optimised as its ambient light sensor keeps the backlight at the best brightness levels, avoiding the screen from dazzling you when it gets dark, whilst keeping it bright and visible during the day.
Monitor data in freely-configurable pages: MXP Strada shows together with RPM scale, all the data you need, like speed, water temperature and oil pressure and much  more. You can choose the custom pages you wish including up to four additional fields, from a wide library of page styles defining which data is to be shown, their end of scale and measure units. Swapping between the pages is easy using the push buttons.
Flexible shift lights and alarms: The 10 multi-coloured RGB shift lights can be customised to your liking, defining the RPM threshold for each single gear. The same flexibility applies to the configurable RGB alarm LEDs. You can configure them in order to turn them on/off depending on analogue or digital inputs, ECU values, expansion values, math channels or - optionally - GPS information. You choose conditions and colours. Select a solid alarm or flashing one - and the flashing frequency. It is also possible to configure an accompanying text message on the display, and set the alarm priorities.
CAN output: With the CAN output you can send messages directly to an existing CAN network in order to improve the range of vehicle control possibilities.
Digital output: MXP Strada features two digital outputs. These LOW SIDE type (switch to ground) can be configured in order to be activated/deactivated depending on the value of the analogue/digital inputs. This allows you to automatically run external systems, i.e. to switch on/off additional lights or to activate/de-activate a cooling fan or circulation pumps etc when a certain event happens.
 Camera inputs: Two analog camera inputs are available, to switch your display into a mirror camera, through pushbutton command or event management.
Compare AiM Dashes
Unlock your potential
AiM MXP IVA Compliant 6" Dash Display Kit
  • Display: 6" TFT
  • Contrast: 600:1
  • Ambient light sensor: Yes
  • Alarm display icons: Yes - Freely configurable
  • Shift lights: 10 RGB LEDs
  • Alarm LEDs: 5 RGB LEDs
  • CAN connections: 3
  • ECU connections: CAN, RS232 or K-Line
  • ECU compatibility: 1,000+ industry leading ECUs
  • Expansion CAN connection: GPS Module, Channel Expansion, Thermocouples expansions, Lambda Controller, SmartyCam HD
  • Analog inputs: 8 fully configurable, max 1,000 Hz each
  • Digital inputs: 1 Speed input, coil RPM input
  • Digital outputs: 1 (1 A max)
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Pushbuttons: Metallic
  • Connectors: 2 AMP connectors + 1 Binder connector
  • Power consumption: 189.6 x 106.4 x 24.9mm
  • Weight: 590g
Search compatible ECU's by manufacturer supported by AiM
Click here >
AiM MXP 360° View
MXP 1.2 Strada Display with Road Icons
  • MXP Strada 1.2
  • 23 Pin Loom IVA Loom
  • 14 Pin Loom
  • Wheel Speed Sensor
