FREE Shipping NEXT DAY Delivery Call +44 (0)1782 393843 Shop now, pay later
MXP Suzuki Logger with CAN Connection
£1,795.00
AiM MXP Dash Logger features a 6" wide colour TFT display, offering a great visual impact.
Key Features:
  • 6" TFT display
  • Configurable display
  • 5 configurable RGB LEDs
  • 10 configurable shift lights
  • 8 analog inputs
  • Wi Fi connectivity
AiM MXP TFT Dash Logger.
The MXP Dash Logger features a 6' wide colour TFT display which offers great visual impact. It is configurable to show all the data coming from your vehicles engine control unit (ECU).
The dash logger has an integrated shift array and configurable multicolour alarms, also drag and drop multi-page configuration. With Wi-Fi and USB connectivity, GPS module, Inertial platform, analog and digital inputs, motorsport connectors, 4GB of internal memory, 1,000Hz per channel sampling and support for over 1,000 ECU connections.
GPS Module
The GPS module option provides easy lap timing and lap position for track mapping with over 4000 tracks in the database.
The GPS module is available with various lead lengths to suit differing applications.
High Contrast TFT Display
The MXP dash logger has a high contrast 6" TFT display. It's visual quality is optimised as the ambient light sensor keeps the backlight at the best brightness levels, avoiding the screen from dazzling you when it gets dark, whilst keeping it bright and visible during the day.
Monitor Data
MXP can define all the custom pages you want. The MXP shows together with RPM scale. All the data you need like speed, water temperature, oil pressure and much more.
You can choose the custom pages you want, with four additional fields from a wide library of page styles. Which define which data you want to be shown with end scale and measuring units. You can swop between pages using the push buttons.
Flexible Shift Lights & Alarms
The 10 multi-coloured RGB shift lights can be customised to how you want them, defining the RPM threshold for each single gear. The same flexibility applies to the configurable RGB alarms LEDs, you can configure them in order to turn them on / off depending on analogue or digital inputs, ECU values, expansion values, math channels or GPS information.
You choose the conditions and colours. Select a solid alarm or a flashing one, also the flashing frequency. It is also possible to configure an accompany text message on the display and set the alarm priorities.
CAN Output & Digital Output
With the CAN Output you can send messages directly to an existing CAN network in order to improve the range of vehicle control possibilities. MXP features two digital outputs. These LOW SIDE type (switch to ground): can be configured in order to be activated/deactivated depending on the value of the analogue/digital inputs. This allows you to automatically run external systems, i.e. to switch on/off additional lights or to activate/de-activate a cooling fan or circulation pumps etc when a certain event happens.
Wi-Fi Connectivity
Configure, calibrate and download your data wirelessly over a secure 802.11 WiFi connection. Once the initial setup / configuration has been done using the USB cable, there is no need to use the cable again.
MXP Connection Examples
Compare AiM Dashes
Unlock your potential
AiM MXP 6" TFT Display Dash Data Logger
  • Display: 6" TFT
  • Resolution: 800x480 pixels
  • Contrast: 600:1
  • Ambient light sensor: Yes
  • Alarm display icons: Yes, freely configurable
  • Shift lights: 10 configurable RGB LEDs
  • CAN connections: 3
  • ECU connections: CAN, RS232, K-Line
  • ECU compatibility: 1,000 + industry leading ECUs
  • Expansion CAN connection: GPS Module, Channel expansion, TC hub, lambda controller, Smartycam HD
  • Analog inputs: 8 fully configurable, max 1,000 Hz each
  • Digital inputs: 4 speed inputs, lap signal, coil RPM input
  • Digital outputs: 2 ( 1 A max each)
  • Second CAN: Yes
  • Wi-Fi connection: Yes
  • Internal platform: Internal 3 axis +5G accelerometer + 3 axis gyro + 3 axis magnetometer
  • Internal memory: 4 GB
  • Body: Aluminium
  • Pushbuttons: Metallic
  • Connectors: 2 Motorsport + 1 Binder connector
  • Power consumption: 400 mA
  • Weight: 640g
AiM MXP 6" TFT Product View
  • MXP Dash Display
  • 37 pins standard harness
  • GPS08 Module
  • AIM Sticker
