MXS Aprilia Logger with CAN Connection
The MXS 1.2 TFT is a dash logger designed to acquire and display data coming from your ECU.
Key Features:
AiM MXS 1.2 Dash LoggerThe AiM MXS 1.2 5" display is fully configurable and easy to use. The dash logger has been designed to acquire and display data coming from the ECU, the internal accelerometer and gyro, as well as the GPS Module that is included in the kit, analog and digital inputs and predefined math channels. Performance and data acquired can also be incremented adding up to eight expansion modules. The 5" display has been designed for small cockpit installation.
The data you sample depends on the ECU but typically includes, RPM, engine load, throttle position, (TPS), oil, air, water temperature, battery voltage, speed gear, lambda value (air, fuel ratio). There are 1000+ different ECUs which are constantly updated and upgraded for stock or racing. |
The CAN output can send messages directly to an existing CAN network which will improve the range of your car's control possibilities. |
Flexible AlarmsSix configurable RGB alarm LEDs. You choose the conditions, you choose the colours. Select a solid alarm or flashing one - and the flashing frequency, choose to have an accompanying text message, and set the alarm priorities. Integrated shift light - Choose from a host of advanced multi-coloured RGB shift light patterns that can be customised to your liking, and for each unique gear when required. |
The MXS has an integrated 10 LED shift light. Chose from a host of advanced multi coloured RGB shift light patterns that can be customised to your liking, also for each unique gear when required. |
GPS Module
MXS Connection Example |
MXS 1.2 TFT Digital Display and Data Logger
- Display: 5" TFT
- Contrast: 6000:1
- Ambient Light Sensor: Yes
- CAN Connections: 3
- ECU Compatibility: + 1000 industry leading ECUs
- Expansion CAN Connection: GPS, Channel expansion, Thermocouple expansions, Lambda controller, SmartyCam HD
- Analog inputs: 8 fully configurable, max 1000 Hz each
- Digital inputs: 4 speed inputs, lap signal, coil RPM input
- Digital outputs: 2 (1 A max each)
- Second CAN: Yes
- Wi-Fi Connection: Yes
- Accelerometer: Internal Three-axial + 5G + Three-axial Gyroscope
- Internal memory: 4 GB
- Body: Anodised Aluminium
- Connectors: 2 motorsport connectors = 1 Binder connector
- Power consumption: 400 mA
- Dimensions: 169.4x97x23mm
- Weight: 530g
MXS 1.2 TFT Digital Display & Dash Logger
- MXS 1.2
- 37 pins standard harness
- GPS Module with cable
- USB cable
- Sticker
