MXS Dash Bracket – AimShop.com
MXS Dash Bracket
SKU: UP-MXL
Availability: 12 in stock
£20.40
QTY:
Trust Badge
MXS Dash Bracket. Due to the size of the Dash, this will probably more likely be used with our single mount centre hub on the steering column or our chassis weld on and bolt on tabs. Though this will work with out steering wheel mounts if you prefer.
  • 160mm x 60mm bolt holes for dash.
  • Optional Weld on tab for your chassis or steering column.
  • 2mm thick in Raw Stainless Steel
Our Modular Steering Wheel Components are Stainless Steel (raw finish) interchangeable components to facilitate the mounting of displays / buttons / dash / lap timers / shift lights.
