Free Shipping Next Day Delivery +44 (0)1782 393843 Shop now, Pay Later
MXS Strada BMW IVA 5" TFT Display Plug & Play Kit
£800.00
The road legal - MOT approved, IVA compliant digital dash display is a complete road legal display solution.
Key Features:
  • 5"  high contrast TFT display
  • Road legal, MOT approved
  • CAN output
  • ECU connection
  • Wheel speed sensor
  • Simple connection harness
Please Note: Don't forget to check out the optional extras at the top of this page where you will find the GPS Module with a length of cables to fit your requirements, a reversing / mirror camera with different patch lead lengths and many more items to help with your build.
The AiM MXS 1.2 Strada IVA Compliant dash kit has a 5" colour TFT display. And is one of the most widely used dashes on road and tracks all over the world. It has an exceptional visual impact and configurable to show all the information coming from the Engine Control Unit (ECU), analogue / digital inputs, pre-defined math channels and the optional GPS Module.
Aim IVA Approved Plug & Play Kit
Our system allows you to see and monitor all ECU information and Odometer, Oil Temperature, Hazards, Main Beam, Engine Temperature, Front Fog, Dipped Beam, Fuel Level, Rear Fog, LH Indicator, Side Lights, Parking Brake, RH Indicator.
Connecting the MXS 1.2 Strada dash to your ECU is very simple. You can sample and display dozens of channels straight from the vehicles ECU. This is usually the quickest and easiest setup needing only 2 cable connections to the ECU instead of multiple connections to analogue sensors.
High Contrast TFT Display: its visual quality being always optimised as its ambient light sensor keeps the backlight at the best brightness levels.
Monitor data in pre-configured pages: MXS 1.2 Strada shows with RPM scale, all the data you need like speed, water temperature and oil pressure, lap times and much more... you can choose the custom pages you wish including up to four additional fields among a wide library of page styles, defining which data to be shown, their end of scale and measure units. Swapping between the pages is easy using the push buttons.
Flexible shift lights and alarms: The ten multi-coloured RGB shift lights can be customised to your liking defining the RPM threshold for each single gear. The same flexibility applies to the configurable RGB alarm LEDs, you can configure them in order to turn them on/off depending on analogue or digital inputs, ECU values, expansion values, math channels or optionally GPS information. You choose conditions and colours: select a solid alarm or flashing one and the flashing frequency. It is also possible to configure an accompanying text message, and set the alarm priorities.
CAN output: With the CAN output you can send messages directly to an existing CAN network in order to improve the range of vehicle control possibilities.
Digital output: MXS 1.2 Strada features a 1 amp digital output configurable in order to be activated/deactivated depending on the value of the analogue/digital inputs or on impulses coming from the ECU. This allows you to automatically run external systems, i.e. to switch on/off additional lights, to activate/de-activate a cooling fan or circulation pumps etc when a certain event happens.
Camera inputs: Two analog camera inputs are available, to switch your display into a mirror camera, through pushbutton command or event management.
Compare AiM Dashes
MXS 1.2 Strada Display with Road Icons
  • Display: 5" TFT
  • Resolution: 800x480 pixels
  • Contrast: 600:1
  • Brightness: 700cd/m2-1,100 Lumen
  • Ambient light sensor: Yes
  • Alarm LEDs: 6 RGB freely configurable
  • Shift lights: 10 integrated freely configurable RGB LEDs
  • CAN connections: CAN, RS232 or K-Line ECU
  • Compatibility: + 1000 industry leading ECUs
  • Expansion CAN connection: GPS, channel expansion, TC hub, Lambda controller, SmartyCam HD
  • Analog inputs: 1 speed input, coil RPM input Digital outputs: 1 (1 A max)
  • Second CAN: Yes
  • Body: Anodised Aluminium
  • Pushbuttons: Metallic Connectors: 2 AMP connectors
  • Dimensions: 169.4x97x23mm
  • Weight: 480g
Search compatible ECU's by manufacturer supported by AiM
Click here >
AiM MXS 360° View
  • MXS Strada 1.2
  • 23 Pin Loom
  • 14 Pin Loom
  • Wheel Speed Sensor
