FREE Shipping NEXT DAY Delivery Call +44 (0)1782 393843 Shop now, pay later
MXS Yamaha Logger with CAN Connection
£1,695.00
The MXS 1.2 TFT is a dash logger designed to acquire and display data coming from your ECU.
Key Features:
  • Compact 5" TFT display
  • GPS Module included
  • 6 configurable RGB LEDs
  • Two digital outputs
  • Wi-Fi connectivity
  • 37 pin harness
  • Free race studio 3 download
AiM MXS 1.2 Dash Logger
The AiM MXS 1.2 5" display is fully configurable and easy to use.
The dash logger has been designed to acquire and display data coming from the ECU, the internal accelerometer and gyro, as well as the GPS Module that is included in the kit, analog and digital inputs and predefined math channels.
Performance and data acquired can also be incremented adding up to eight expansion modules. The 5" display has been designed for small cockpit installation.
Connecting the MXS 1.2 dash logger to your ECU is very simple. You can sample dozens of channels straight from your vehicles ECU. This is the quickest setup as you only need one connection cable to the ECU instead of multiple connections to analogue sensors.
The data you sample depends on the ECU but typically includes, RPM, engine load, throttle position, (TPS), oil, air, water temperature, battery voltage, speed gear, lambda value (air, fuel ratio).
There are 1000+ different ECUs which are constantly updated and upgraded for stock or racing.
CAN Output
The CAN output can send messages directly to an existing CAN network which will improve the range of your car's control possibilities.
High Contrast 5" TFT Display
Fully configurable using the powerful dedicated software. Create and customise as many pages / displays as you wish, using different fonts and dimensions for all information received by the MXS dash logger.
Swapping between pages can be managed by pushing one or two pushbuttons. An ambient light sensor keeps the backlight at optimum brightness levels.
Flexible Alarms
Six configurable RGB alarm LEDs. You choose the conditions, you choose the colours. Select a solid alarm or flashing one - and the flashing frequency, choose to have an accompanying text message, and set the alarm priorities. Integrated shift light - Choose from a host of advanced multi-coloured RGB shift light patterns that can be customised to your liking, and for each unique gear when required.
Integrated Shift Light
The MXS has an integrated 10 LED shift light. Chose from a host of advanced multi coloured RGB shift light patterns that can be customised to your liking, also for each unique gear when required.
GPS Module
GPS is included in the kit. Thanks to being lightweight and waterproof the GPS Module and the GPS software, you can immediately get your lap times and all the data needed for engine tuning as well as enhancing your driving technique.
The GPS Module is fast in satellite signal acquisition and reliable in adverse situations.
The GPS Module helps you get the important data such as chassis analysis, track position, speed, cornering in-line, lateral G and automatic lap times.
MXS Connection Example
MXS 1.2 TFT Digital Display and Data Logger
  • Display: 5" TFT
  • Contrast: 6000:1
  • Ambient Light Sensor: Yes
  • Alarm LEDs: 6 RGB freely configurable
  • Shift Lights: 10 integrated freely configurable RGB LEDs
  • CAN Connections: 3
  • ECU Compatibility: + 1000 industry leading ECUs
  • Expansion CAN Connection: GPS, Channel expansion, Thermocouple expansions, Lambda controller, SmartyCam HD
  • Analog inputs: 8 fully configurable, max 1000 Hz each
  • Digital inputs: 4 speed inputs, lap signal, coil RPM input
  • Digital outputs: 2 (1 A max each)
  • Second CAN: Yes
  • Wi-Fi Connection: Yes
  • Accelerometer: Internal Three-axial + 5G + Three-axial Gyroscope
  • Internal memory: 4 GB
  • Body: Anodised Aluminium
  • Pushbuttons: Metallic
  • Connectors: 2 motorsport connectors = 1 Binder connector
  • Power consumption: 400 mA
  • Dimensions: 169.4x97x23mm
  • Weight: 530g
Search compatible ECU's by manufacturer supported by AiM
Click here >
AiM MXS Car Racing Dash Logger
MXS 1.2 TFT Digital Display & Dash Logger
  • MXS 1.2
  • 37 pins standard harness
  • GPS Module with cable
  • USB cable
  • Sticker
