Karting's favourite system just got better.
The all new MyChron5 S 2T is our latest game changing data logger for Kart Racing.
Key Features:
AiM MyChron5 S 2T the new and improved latest version of our game changing datalogger / lap timer designed precisely for kart racing has landed. The GPS frequency has improved from 10 to 25 Hz and the precision accuracy has improved from 5 feet to 2 (1.5 to 45 cm approximately). A more powerful processor, making the MyChron 5 S 2T 2 times faster than the current MyChron and with much more memory, with more firmware features being developed.
The system takes advantage from an internal wide track database, in order to automatically understand at which track you are at, where and how many are the magnetic strips: without any further sensor or configuration you will automatically get lap times, predictive lap times and split times. GPS data, acquired ten times per second, are of course recorded with other signals in the internal data logger, in order to offer the possibility of a deeper analysis of your performance. |
Shift light & alarm LEDs Five RGB shift lights can be configured for each gear, choosing LED colour and RPM threshold values which will turn them on/off. They also allow RPM monitoring in a glance. Even alarms are managed in a very flexible way: you choose the situation that generates the alarm, the LED behaviour (blinking frequency and colour) when the alarm appears and the conditions for its switch-off. |
Download your data to your PC, look at the OnLine measures, upgrade your firmware, transmit parameters using the well-known Data Key or through fast WiFi connection. |
MyChron5 S expansions and add-ons |
Learn more and trade up today > |
MyChron5 S 2T Water Temperature Sensor
- GPS: 25Hz
- Inertial Platform: Included
- Wi-Fi Connection: Included
- Display Resolution: 268 x 128 pixel
- Backlight: 8 configurable RGB colours
- Ambient Light Sensor: Yes
- Multifunctional LEDs: 5 RGB LEDs
- Alarm LEDs: 2 configurable
- RPM sampling frequency: 50 HZ
- Body: Glass fibre reinforced nylon
- Battery: Rechargeable Lithium
- Memory: 4 GB
- Dimensions: 137 x 88 30mm
- Weight: 390g
- Mychron 5 S 2T
- Battery Charger with Cable
- RPM Cable
- Temperature Sensor
