Karting's favourite system just got better.
The all new MyChron5 S is our latest game changing data logger for Kart Racing.
Key Features:
The GPS frequency has improved from 10 to 25Hz and the precision accuracy has improved from about 5 feet to 2 (1.5 m to 45 cm in average). |
MyChron 5S features 1 temperature sensor input which can be used to measure one of the following sensors, water temperature, under spark plug cylinder head temperature (CHT) or exhaust gas temperature (EGT) |
Shift Light & Alarm LEDs Five RGB shift lights can be configured for each gear, choosing LED colour and RPM threshold values which will turn them on/off. They also allow RPM monitoring in a glance. Even alarms are managed in a very flexible way: you choose the situation that generates the alarm, the LED behaviour (blinking frequency and colour) when the alarm appears and the conditions for its switch-off. Monitor water temperature or any other parameter with configurable alarm LEDsYou can configure alarm LEDs as well, in order to turn them on/off depending on the values you selected: water temperature or any other parameter you may need. |
Download your data to your PC, look at the OnLine measures, upgrade your firmware, transmit parameters using the well-known Data Key or through fast WiFi connection. |
MyChron5 S expansions and add-ons |
Learn more and trade up today > |
MyChron5 S 2T Water Temperature Sensor
- GPS: 25Hz
- Inertial Platform: Included
- Wi-Fi Connection: Included
- Display Resolution: 268 x 128 pixel
- Backlight: 8 configurable RGB colours
- Ambient Light Sensor: Yes
- Multifunctional LEDs: 5 RGB LEDs
- Alarm LEDs: 2 configurable
- RPM sampling frequency: 50 HZ
- Body: Glass fibre reinforced nylon
- Battery: Rechargeable Lithium
- Memory: 4 GB
- Dimensions: 137 x 88 30mm
- Weight: 390g
- Mychron 5 S 2T
- Battery Charger with Cable
- RPM Cable
- Temperature Sensor
