Karting's favourite system just got better.
The all-new MyChron5 S is our latest game-changing data logger for Kart Racing.
Key Features:
The GPS frequency has improved from 10 to 25 Hz and the precision accuracy has improved from about 5 feet to 2 (1.5 m to 45 cm in average). |
Redesigned Wi-Fi Module: a new firmware is under test for improving the baud rate. The data download will be 5 times faster. |
MyChron5S offers the opportunity to download the data wirelessly, using an easy and safe Wi-Fi connection: no data key or PC connection are needed anymore. Wi-Fi data transfer is easily configurable via PC or keyboard. In case of a connection of more than one gauge/PC (a typical situation in a team) it is possible to transfer data to/from all MyChron5S devices and PC's at the same time. In this case you would need to buy an access point, which will act as a bridge between the gauges and the PC's. |
MyChron5 S expansions and add-ons |
A glass fiber reinforced Nylon body along with metal buttons and anti-scratch non-reflecting polycarbonate display guarantee MyChron5S top resistance to shocks and adverse weather conditions. |
Learn more and trade up today > |
MyChron5 S 2T Water Temperature Sensor
- GPS: 25Hz
- Inertial Platform: Included
- Wi-Fi Connection: Included
- Display Resolution: 268 x 128 pixel
- Backlight: 8 configurable RGB colours
- Ambient Light Sensor: Yes
- Multifunctional LEDs: 5 RGB LEDs
- Alarm LEDs: 2 configurable
- RPM sampling frequency: 50 HZ
- Body: Glass fibre reinforced nylon
- Battery: Rechargeable Lithium
- Memory: 4 GB
- Dimensions: 137 x 88 30mm
- Weight: 390g
- Mychron 5 S 2T
- Battery Charger with Cable
- RPM Cable
- Temperature Sensor
