RaceTPMS Motorcycle Tyre Pressure Management System – AimShop.com
SKU: R-TPMS-V2-85-BIKE
Availability: Many in stock
£766.80
QTY:
Trust Badge
The RaceTPMS Motorcycle Tyre Pressure Management System (TPMS) is perfect for basic motorcycle racing applications where multiple wheels are used and spare sets needed. Up to 16 wheel sensors are able to be used allowing pressures and temperatures to be checked without touching the wheel.
During use, pressure and temperature are displayed simultaneously and highest temperature and pressure can be recalled on the diplay unit. Wheel changes mean that the display unit recognises and displays the relevant data in the display unit.
Features include;
LCD Display
Motorcycle TPMS sensors main features
  • Shows real time Pressure and Temperature simultaneously for front and rear tyres.
  • Recalls highest temp or pressure after every session.
  • Warning alert if tyre loses pressure or high temperature (threshold can be set as desired and front and rear independently).
  • Can be easily removed from bike and worn by tyre technician to monitor spare wheels for pressure/temperature without using tyre gauge. Just use the LF switch to turn sensors on and off as required.
3 Button LF Trigger
Turns wheel sensors on and off to transmit information to your display unit.
3 Button LF Trigger
Wheel Sensors
  • High performance material to endure centrifugal stress
  • Simple and robust concept to adapt the sensor on all rims
  • Standard nuts and external rim cosmetic
  • The number of wheel sensors you can have is optional from 2 to 16 depending on your requirements.
  • This is a race proven product and every racer would benefit from this sort of information.
  • Standard Sampling :1 Hz for Pressure & T(1 race season life)
  • Monitored temperature range :-40C to +125C (temperature scenario)
  • Measuring pressure range :0 to 3,5 bar
  • Monitored acceleration range :0 to 2000G (360 km/h @ 19’)
  • Wheel unit weight :31 g
  • Pressure accuracy :13.7 mbar
  • Temperature accuracy :1C
  • RF transmission :FSK / 434 MHz
The Kit includes:
1 x LCD Display
1 x LF Trigger
Choice of 2 or 4 x Wheel Sensors
Manual
Download Manual
FAQ
Frequently Asked Questions
Q: How does it work?Sophisticated electronic sensors measure pressure and temperature and wirelessly transmit a signal to the display mounted on your dash where you can see the information in real time.
Q: Do the sensors go on the valve stem?No. Race TPMS sensors go inside the tyre. This enables them to measure tyre temperature as well as pressure and it is a much more accurate and sophisticated sensor than the external ones avaialable. It is also more secure and safe from road debris etc.
Q: How do I know they are quality?Tire Watch has been selected by BMW, Honda, Kawasaki and Triumph as genuine fitment for use on their models that come with tyre monitoring as either standard or optional. These manufacturers demand the very best quality and safest technology available.The Race TPMS Road kit we offer also has features not offered on the genuine equipment models such as tyre temperature and adjustable thresholds.
Q: Does it fit my bike?Yes, if you have a road bike with tubeless tyres it is 99% sure to fit!
Race TPMS fits pretty much all tubeless motorcycles and scooters.Our Race TPMS kit comes with several adaptors to cover most bikes. One kit fits all!Please feel free to contact us if you have any questions.
Q: Is it hard to fit?It is very easy to install!Once you have chosen where you would like the display to go you can use the components in the kit to mount it quickly. The sensors are mounted inside the tyres so once your tyre shop removes them it literally takes two minutes to install the angled valve and sensor and there are no wires so nothing else to do except go for a ride!
Q: Does it have batteries?For ease of install and operation the unit is wireless and runs on 3V lithium batteries for long life.The display battery has a 2 year life expectancy and the NEW Gen 2 version sensor batteries have a 7 year life expectancy.
Q: What features does it have?Features are-
  • LOW Pressure Warning
  • HIGH Temperature Warning
  • Adjustable Pressure Warning thresholds
  • Identifies Front or Rear Warning
  • Real Time Pressure Readout
  • Real Time Temperature Readout
  • Ambient Temperature Display
  • Clock
  • Metric or Imperial Readout
  • Waterproof
  • Pressure Accuracy 0.290075475 PSI
Bike Compatibility
Motorcycles compatible with 8,5mm Valves
Aprilia
Caponord 1000 ETV / Tuono / RSV 1000 1000R <2005 / Falco 1000 SL / Futura RST1000 / Shiver 750
For the following motorcycles equipped with OZ Racing : RSV 1000 R & Tuono (< 2005) ; R Factory, keep the 11,5 mm serial seal.
Bimota
600 YB9 SRI / 900 DB / 900 Mantra / 1000 DB5 Mille / 1000 SB8 K / 1000 TESI 2D / 1000 YB11 / 1100 SB 6R
Buell
XB9R / XB9S / XB9SX City Cross / 1200 M2 Cyclone / 1200 S1 Lightning / S1 Xhite Lightning / S3 Thunderbolt / X1 Lightning / X1W White Lightning / XB12R / XB12S
Ducati
Monster 600 – 620 – 750 – 800 – 900 – 1000 DS / Multistrada 620 – 1000 DS / SS 600 – 750 – 800 – 900 1000DS / 748 / 749 / 888 / 916 /944 ST2 / 996 / 998 / 999 / ST3 / ST4
KTM
Duke / 990 Super Duke / 950 Supermoto / SM tubless
Moto Guzzi
1000 Daytona RS / 1000 V10 Centauro / 1100 V11 / California EV 1100 / Breva 1100 / Griso 1100 / Norge 1200
MV Agusta
Brutale 750, 910 / F4 750 – 1000
Triumph
Speed Four / Daytona 650 / Daytona 955I / Speed Triple (only 2004) / Sprint ST / Trophy / Rocket III / Tiger 1050
Voxon
Street Scramber / Roadster New and Limited / Cafe Racer / Black Magic / Charade
Motorcycles compatible with 11,5mm Valves
Aprilia
50 SR /Atlantic 500 / 125 300 Laonardo/500 Scarabeo/ 650 Pegaso Strada
BMW
F 650 CS/ R 850RR 1150R (Rockster)/R 850RTR 1150 RT / R 1100 S(BoxerCup Replica) /K 1200 LT / K 1200 GT / R 1200C /K 1200RS / R 1200 CL / R 1200GS
Cagiva
Raptor 650 – 1000 /Navigator 1000
Harley
VRSCR Street Rod
Honda
CBF 600 – 900 – 1000 – 1300 / CBR 600 – 900 – 1000 – 1100/ 650 NT Deauville/ 750 CB Seven-fifty / 750 VFC / 750 VFC2 / 750 VFR F /750 VT C / 800 pacific Coast/ 800 VFR/1000 CB1 F (big one)/1000 VTR/1000 XL V/ST Pan European 1100 1300 / 1100VTC / 1300 VTX S / 1500 GL C-C2 (F6C) / 1500 GL SE Goldwing / 1800 GL Goldwing / 1800 VTX C / 600 Silver Wing
Hyosung
Comet 650
Kawasaki
600 Eliminator / ZX(6R& 6RR) – 636 R -(7R & 7RR) -9R – 10R – 12R / ZZR 600 – 1100 – 1200 – 1400/ 750 Z / 750 ZS/ 750 ZR (7 & 7S)/1000 GTR / 1000 KLV / 1000 Z/ 1100 GPZ/ZRX 1100 / 1200 (R & S)/VN 1500 -1600- 2000 / ER6 ( N & F)
Moto Guzzi
750 Breva ie/
MZ
1000SF / 1000S / 1000ST
Piaggio
Beverly 500 / X8 / X9 Evolution 125 500
Suzuki
GSF 600 – 1200/ GSX 600 (F& R) – 750 (F&R) – 1000 R – 1100 R – 1200 – 1300 R 1400/SV650 – 1000/800 VX /VZ 800 – 1600/ 1000 TL/ 1500 VL
Yamaha
Fazer 600 – 1000/ 600 XJ/ YZFR6 – R7 R1 / 660 SZR/ TDM850 – 900/850 TRX/900 GT /900 XJS/ 1100 BT/XJR 1200 1300 /1300 FJR/ XV1600 1700 /1700 MT 01 / 500 TMAX
NON COMPATIBLE MOTORCYCLES
Triumph
Speed Triple from 2005 / Sprint ST from 2006
BMW
F 800 S / F 800 ST / BMW rims with valve in spoke manufactured end of 2005 – no threading
Fitting Tips
The Road version kit comes set up for the most common used rubber valves (Japanese bikes) so no fiddling with other adaptors, just go ahead and fit!
For all other bikes check the instructions for which seal and nut to use.
ANGLED VALVE FITTING
When fitting the angled valves supplied in the kit, them point them towards the right hand side of the bike. This will mean when its on the side stand you will have easy access to the valves with your air chuck or pump.
SENSOR ID ACTIVATION
When first fitting the kit, the dash needs to learn the ID of the sensors fitted. To do this turn the display on to the ID screen then ride away on the motorcycle and stay above 20kph for a few minutes until the display recognises both wheels.
OPERATIONAL
To flick between the temperature and pressure screens just press the right hand button on the display.
TYRE FITTERS PLEASE NOTE!
When removing/installing tyres with sensors fitted, always- Break bead away from valve area.
  • Start with tyre machine tool away from valve.
  • Do not cross valve area with tyre machine tool.
TIRE WATCH OWNERS PLEASE NOTE!
When getting a new tyre fitted remember to advise the tyre fitter that you have sensors fitted and to take care-see above.
