Same-day dispatch
on orders before 3pm
Finance available
on selected products
First-class support
SB12V20P-SC Super B Motorsport Lithium Race Car Battery
£766
SB12V20P-SC Super B Motorsport Lithium Race Car Battery is a lightweight Lithium Ion starter battery, 7.94 lb / 3.6 kg, specially developed for MotorsportSafety Super B batteries are based on...
Safety
Super B batteries are based on Lithium Iron Phosphate technology (LiFePO4). This Lithium Ion technology used in super B batteries is the safest Lithium Ion technology available today. On top of that our bespoke casing and electronics further increase safety and durability.
Use
Please take the advice below into account while using the battery.
1. Do not jumpstart.
2. Use correct charger.
3. Make sure the battery does not get deeply discharged. If the battery has no charge remaining when you check it, consider it to be damaged. Do not attempt to recharge or use it.
4. This battery is specially developed for motorsport. If you want to use it on road, please consult Super B.
Applications
  • DTM,
  • Group C,
  • WRC,
  • BTCC,
  • WTCC,
  • NASCAR,
  • LMS,
  • GT's,
  • GT Endurance,
  • Dakar Rally Raid,
  • Britsports,
  • ALMS,
  • 4x4
Technical specifications
SKU/EAN13 8718531360075
Battery Designation : 4IFP97/250/142-8
Height (mm) : 140,30 / 141,30
Diameter (mm) :  NA
Width (mm) :  248,35 / 249,35
Thickness (mm :  95,25 / 96,25
Nominal voltage (V) :  13,2V
Charge method :  CCCV
End of charge voltage (V) :  15,2V
End of charge voltage (V) for endurance (cycle life) :  14,4V
Charge current (A) : 80A (4C)
Charge current (A) for endurance (cycle life) :  24A (1C)
End-of-discharge voltage (V) :  8V
End-of-discharge voltage (V) for endurance (cycle life) :  10V
Discharge current (A) :  560A (30C)
Discharge current (A) for endurance (cycle life) :  18,4A (1C)
Discharge pulse current (A) (10 seconds) :  960A (52C)
Discharge pulse current (A) (1 second) :  1200A (65C)
Discharge performance at 20 °C (rated capacity) :  18,4Ah / 242,88Wh
Discharge performance at –20 °C (capacity) :  16,56Ah / 218,592Wh
High rate discharge performance at 20 °C (capacity) :  17,48Ah / 230,736Wh
EqPb (Equals Lead acid battery) :  70 to 100Ah
Operating temperature range :  -30°C to +60°C
Storage temperature range :  -50°C to +60°C
Weight :  3,6kg
