{"product_id":"second-life-aim-6-tft-pdm-dash-display-with-race-icons","title":"Second-Life Aim 6\" TFT PDM Dash Display with Race Icons","description":"\u003cdiv class=\"rte siteMaxWidth body subtext-md leading-normal\"\u003e\n\u003cdiv class=\"metafield-rich_text_field\"\u003e\n\u003cp\u003e\u003cem\u003e\u003cstrong\u003eThis MXT is fully equipped and ready to take on its second life. The product is in full working order at a reduced price, and has been meticulously checked by our technicians.\u003c\/strong\u003e\u003c\/em\u003e\u003c\/p\u003e\n\u003c\/div\u003e\n\u003c\/div\u003e\n\u003cp\u003eAdvanced PDM Display\u003cbr\u003eThe 10\" PDM display with road icons is one of the most widely used PDM displays on roads around the world. It’s suitable for use as a replacement unit for those supplied with the Aim PDM kits or an upgrade for PDM kits that do not include a dash display.\u003c\/p\u003e\n\u003cp\u003eWhy Choose the 10” PDM Display\u003cbr\u003eThe 10\" PDM display is a TFT dash display suitable for replacing all of the dashboard gauges and warning lamps. The displays are available in 5”, 6\" or 10\" versions and with both \"Road\" or \"Race\" icon options. All versions have fully user-configurable displays and offer a range of layouts.\u003c\/p\u003e\n\u003cp\u003eCheck out the free downloads tab for all the information required on connection and programming to the PDM08 and the PDM32.\u003c\/p\u003e\n\u003cp\u003ePlease Note: The 10\" dash display is ONLY for use with Aim PDM kits and can not be used as a stand-alone dash display.\u003c\/p\u003e\n\u003cp\u003eDisplay with Road Icons\u003cbr\u003eThe dash has a 10\" TFT high contrast colour display. The visual quality is optimised by the ambient light sensor, which keeps the backlight at the best brightness levels.\u003c\/p\u003e\n\u003cp\u003eRoad icons allow you to apply conditions to the LED icons, such as fuel, engine, oil, lights, indication and more.\u003c\/p\u003e\n\u003cp\u003eAim 10\" TFT Dash Display with Road Icons for PDM08\/PDM32\u003cbr\u003eExpand Your System\u003cbr\u003eAdd extra devices to your system to give additional data to improve your driving performance, such as a GPS Module, TC Hub, SmartyCams, LCU-One S Lambda Controller, Formula Steering Wheels, TPMS System and keypads.\u003c\/p\u003e\n\u003cp\u003eThe 10\" road display also doubles up as a reversing mirror using a separately available camera—ideal for cars with limited rear vision. You can add up to 2 cameras for both front and rear views. The camera is sold separately.\u003c\/p\u003e\n\u003cp\u003eNote: You will require a PDM32 for this to work.\u003c\/p\u003e","brand":"Second-Life","offers":[{"title":"Default Title","offer_id":45010564644966,"sku":"SN:7901119","price":289.0,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0214\/9392\/files\/PDMDash.png?v=1773157578","url":"https:\/\/www.aimshop.com\/products\/second-life-aim-6-tft-pdm-dash-display-with-race-icons","provider":"AimShop.com","version":"1.0","type":"link"}
