Smartycam GP HD Rev 2.2 Kart Bullet Camera
£800
AiM SmartyCam Bullet GP HD Rev 2.2 Bullet Kart Camara The AiM SmartyCam GP HD Rev 2.2, Motorsport...
The AiM SmartyCam GP HD Rev 2.2, Motorsport Bullet Camera System, is robust, reliable and offers 67° Standard, 84° Medium, and 120° Wide Angle FOV Lenses.
Smartycam GP HD is a very versatile racing camera system. It’s easy to install on most racing vehicles, it’s robust and reliable and has been engineered to withstand the extreme working conditions typical of all Motorsport.
Designed for Motorsports with a single purpose, providing great videos that include all the technical information that will help you improve your performance. All this in the most robust and reliable system ever.
Key Features:
  • H.264, 1,280X720 PIXEL @30FPS Video format
  • Telecentric lens with six elements
  • 67°, 84°, 120° Angle of view
  • internal, rechargeable lithium battery - 1.500 mAh
  • Battery duration: 60' - 70' of recording with data
  • 9 - 15 Volt External Power
  • Support for up to 128 GP SD Cards
  • 3 axis 5g accelerometer
  • -10°c / + 60°c Usage temperatures
  • Auto Power ON / OFF
  • Auto Start / Stop recording
  • 3 Binder 712 female connectors+ 1SMA female connector
  • 2.4" 240x320 Display
SmartyCam GP HD Bullet Rev. 2.2 Competitive Advantages
  • Real time dater overplayed on videos
  • Proprietary lenses designed for motorsports
  • Race Studio 3 for video configuration and anlalysis
  • Front mount coloraturas TFT display for in-car installation
  • Automatic Start & Stop
  • High-quality small-size video files
  • No "wave effect" with the CMOS sensor and improved video quality
  • Designed to withstand extreme on-track working conditions
  • Compact, handy and easy to install
  • Now compatible with GPS08 Module
  • With external microphone / jack
  • Integrated AiM CAN-bus HUB
  • Direct CAN ECU connection
  • Even more powerful battery
Real Time Data Overlaid on Videos
SmartyCam GP HD overlays all the data you need from different sources. From GPS i.e. track map and vehicle position, as well as speed, lap and split times. From Aim loggers connected to your ECU i.e. RPM, throttle, engaged gear, acceleration, temperatures, pressures and – in presence of additional sensors – also their values. All thIs information will be overlaid on videos in each single point of the track.
SmartyCam HD uses Race Studio 3, the powerful software which allows you to configure all details of your videos.
You can configure your overlays in a virtually infinite variety of modes: add your logo and the track map, and choose your graphic objects from a list of pre-determined sets with same layout or even single objects from different sets. Your videos will be truly “yours” in all details, from the data to their graphic layouts.
Video Analysis
The video of a whole session, once downloaded on your PC, can now be split – with a simple click – in individual videos of each lap: so that you can simultaneously watch two of them and check where you were faster or slower. The same operation can be performed with any SmartyCam HD video recorded on the same track: you will be able to compare your best lap with your friends personal best.
The new SmartyCam GP HD Bullet has been designed integrating the direct connection to the CAN-bus line of the ECU and it will allow to use the can-bus communication protocols included in our official database, or manage the customised can-bus protocols.
This new feature has been designed particularly for those vehicle like Formula cars or race bikes, where the available space to fit things in is minimum.
Coaxial bullet cable with dedicated connection
We have introduced new solution in order to make all the connections stronger and more protected by electromagnetic noise, as a new connection cable for the bullet , now more protected, and a stronger filtering on the power connection of the SmartyCam GP HD.
Integrated Aim CAN-bus Hub
SmartyCam GP HD has now 4 connectors, one completely dedicated to the bullet cam, one for the ECU-MIC, one for the GPS08 Module connection and an extra one you can use to add an expansion you might have need.
Now compatible with the GPS08 Module
The new SmartyCam GP HD has been optimized and now can only work with the generic GPS08 Module.
Now with External Microphone / Jack
SmartyCam GP HD is very flexible: you can add optional modules to fit it perfectly to your needs, like the ECU Bridge to connect it directly to the Engine Control Unit, the GPS, or the external microphone/jack.
You are on the starting grid, ready to sprint, your adrenaline reaching the climax: the last thing you can worry about is… switching on the camera. You have other things to worry about. SmartyCam HD Rev2 is aware of that, that is why it switches on/off automatically and starts/stops recording the same way.
Automatic On/Off Switch
SmartyCam HD can be switched on by the logger it is connected to. Switch-off is automatic, simply decide after what period of non-activity the camera will switch-off. Both operations can also be carried out using the keyboard, if you prefer.
Recording
Recording can also be started/stopped automatically or via keyboard. With automatic switch-on, the camera will start recording when the speed or RPM threshold is exceeded. In this case, you simply decide how long after dropping below the selected threshold the video will automatically stop.
No “wave effect” and Improved Quality with The New CMOS Sensor
Engine rumble causes vibrations, which are not a good thing for video recording. Never again will you experience that seasick “wave effect” you get when watching videos recorded by a generic camera, when the car rolls at 7000 RPM. SmartyCam HD has been designed for that environment and for those vibrations. “Wave effect” is just a memory.
The Global Shutter CMOS Sensor
Unlike generic multipurpose cameras, SmartyCam HD Bullet has been designed to avoid the problem of image distortion, thanks to the innovative Global Shutter CMOS sensor. The camera shutter captures the entire image at the same time, not “pixel by pixel” like traditional sensors. The result is that images are captured at once and are not affected by the vibrations that happen on a racing vehicle, which create the so-called “wave effect”.
Proprietary Lenses Designed for Motorsports
A lens specifically designed for Motorsports must be robust, must be able to work when the engine rolls 100 times per second, and have good resolution and brightness. But above all a lens designed for Motorsport must reduce distortion, which is a typical problem of lenses used by generic action-cameras: objects placed at ten metres’ distance look very far away, making it impossible to accurately determine whether the track is straight or curved. SmartyCam HD telecentric lens with six elements reduces distortion to the minimum and will withstand track vibrations for years. Moreover the lenses with different HFOV’s allow a tailor-made framing in all kind of vehicles.
Which Lens?
The narrow 67° HFOV lens is preferred for closed-roof cars, as it “sees” the track just within the wind-screen pillars, reducing that unpleasant black frame around typical of generic camera on-board videos.
The wide 84° HFOV lens is specific for open-roof, formula car and kart use, where it is possible to have a more ample view of the track and there is no risk of black frames.
The wide angle 120° for open roof, formula car and kart use, where it is possible to have a more ample view of the track.
Front Mount Colour TFT Display For In-Car Installation
On-board cameras are to be installed inside the car. Where should the display be placed to check the correct position of the camera? The SmartyCam HD 128x128 pixel TFT colour display is on the front, not on rear – where general cameras place the viewfinder.
 High Motorsport Quality – Small Size Video Files
Most other HD cameras are focused on the highest pixel number. The result is that their video files are far too large, taking too much memory. SmartyCam HD videos have the same quality as other HD cameras but their files are smaller because the H264 compression system parameters have been optimised to a perfect balance between video quality and file size.
You can choose among three video file quality levels: one-hour recording takes 4GB (high quality), 2GB (normal) or 1,5GB (low). Files are stored on SD cards: with current SD cards reaching 128GB capacity, you can record more than 30 hours of high-quality videos without changing the card.
Designed To Withstand Extreme On-Track Working Conditions
Frail things have a bad time on track. An on-board camera designed for Motorsport, must guarantee great resistance against the extreme working conditions typical of track racing and against the most adverse weather, such as strong and prolonged vibrations, storms, continuous rain, and extreme high and low temperatures.
That is why SmartyCam HD Rev 2.2 is made in machinery moulded aluminium used in many competition car parts. The SmartyCam HD Rev 2.2 Bullet is the most robust and reliable system ever.
Compact, handy and easy to Install
Its small size (87x63x49mm) and light weight (just 280g) make SmartyCam HD easy to install inside your car or on your bike.
SmartyCam HD or HD GP Connection
The perfect connection to get all your data from the ECU merge them with the GPS information and transmit everything to the SmartyCam HD then watch the graphical overlay in the video.
Make it even better and add Multiple cameras
SmartyCam connections
The AiM SmartyCam GP HD 2.2 Bullet Camera.
  • Video Format: H.264 1280 X 720 pixels @ 30 fps
  • Display Resolution: 2.4" 240 X 320 pixels
  • Lens: Telecentric with 6 elements
  • Field of View: 67°, 84°, 120°
  • Internal Battery: Rechargeable Lithium Battery - 1,500mAh
  • Battery Charge: 700 mAh 12V
  • Internal Battery Duration: 60- 70 min of recording
  • External Power: 9 - 15 V
  • Supported SD Card: Up to 128 GB
  • Memory Capability: 1.5 GB ( 1 hour low quality recording)
  •                                   2 GB    ( 1 hour medium quality recording)
  •                                   4 GB.   ( 1 hour high quality recording)
  • Accelerometer: Three-axial + 5G
  • Usage Temperatures: _10°C / +60°C
  • Auto Power ON: Yes if connected to the AiM logger
  • Auto Power OFF: Yes
  • Body: Anodized Aluminium
  • Main unit Dimensions: 104.6 x 79.6 x 26.6 mm
  • Bullet camera Dimensions: 24 diam x 48.2mm
  • Connectors: 3 Binder 712 female connectors + 1SMA female connector
  • Bullet Cable Length: 2.0m
  • Main unit Weight: 320g
  • Bullet camera Weight: 45g
  • Waterproof: IP67
AiM SmartyCam GP HD 2.2 Bullet Camera 360° Product View
  • AiM SmartyCam GP HD 2.2 Bullet Camera
  • Dash or Logger Connection Cable, 2m or 4m (as selected)
  • Software Installation CD
