AiM SmartyCam GP HD Rev 2.2 Bullet Camara
SmartyCam GP HD is a very versatile racing camera system. It’s easy to install on motocross bikes, it’s robust and reliable and has been engineered to withstand the extreme working conditions typical of all Motorsport.
Key Features:
Direct CAN ECU connection
The new Rev 2.2 SmartyCam GP HD has been designed integrating the direct connection to the CAN-bus line of the ECU. It allows the use of can-bus communication protocols included in the official AIM database. This new feature has been designed particularly for those vehicles like Formula cars or race bikes, where the available space to fit things in is minimal. Coaxial Connection
The new connection cable for the bullet camera is now more protected from electromagnetic noise, and has stronger filtering on the power connection of the SmartyCam GP HD. Integrated Aim CAN-bus Hub
SmartyCam GP HD Rev 2.2 now has 4 connectors, one completely dedicated to the bullet cam, one for the ECU-MIC, one for the GPS08 Module connection and an extra one to add any expansion that you might need. |
Designed for extreme conditionsAn on-board camera designed for motorsports must continue to work in the most extreme working conditions typical of track racing and against the most adverse weather, such as: strong and prolonged vibrations, continuous rain and extreme high and low temperatures. That is why the SmartyCam GP HD is made in machinery moulded aluminium, just like many competition car parts. |
Other generic action cameras are designed to record video in many different situations, but in motorsports they tend to record misleading videos making it difficult to tell if a section of track is straight or curved. Being a camera dedicated to motorsports, the SmartyCam GP HD features lenses specifically designed to avoid distortion.
The camera is available in three lens versions and each with a choice of 2 or 4 metre length cable: |
Higher Storage CapacityUsing a compression system which has been optimised to provide the perfect balance between video quality and file size. Video is stored on an SD card and you can select 3 different recording quality options: High quality, 1 hour = 4GB, Standard quality - 1 hour = 2GB, Low quality - 1 hour = 1.5GB. This means that with a 128GB SD card you can store over 32 hours of footage. |
Unlock your potential
- Video Format: H.264 1280 X 720 pixels @ 30 fps
- Display Resolution: 2.4" 240 X 320 pixels
- Lens: Telecentric with 6 elements
- Field of View: 67°, 84°, 120°
- Internal Battery: Rechargeable Lithium Battery - 1,500mAh
- Battery Charge: 700 mAh 12V
- Internal Battery Duration: 60- 70 min of recording
- External Power: 9 - 15 V
- Supported SD Card: Up to 128 GB
- Memory Capability: 1.5 GB ( 1 hour low quality recording)
- 2 GB ( 1 hour medium quality recording)
- 4 GB. ( 1 hour high quality recording)
- Accelerometer: Three-axial + 5G
- Usage Temperatures: _10°C / +60°C
- Auto Power ON: Yes if connected to the AiM logger
- Auto Power OFF: Yes
- Body: Anodized Aluminium
- Main unit Dimensions: 104.6 x 79.6 x 26.6 mm
- Bullet camera Dimensions: 24 diam x 48.2mm
- Connectors: 3 Binder 712 female connectors + 1SMA female connector
- Bullet Cable Length: 2.0m
- Main unit Weight: 320g
- Bullet camera Weight: 45g
- AiM SmartyCam GP HD 2.2 Bullet
- Software Installation CD
