SmartyCam HD U Bolt Mount for Kart
£52
The SmartyCam, HD U Bolt Mount, is made of engineered anodised aluminium and designed to fix the Smartycam...
The SmartyCam, HD U Bolt Mount, is made of engineered anodised aluminium and designed to fix the Smartycam HD to roll bar or tubular fixing.
In the box:
  • 1x U-bolt + straps
  • 1x 60 mm single ball arm
  • 1x Ball head
  • 1x washer diameter 17.7mm, thickness 1.5mm, hole 6mm
Aim Technologies are committed to supplying professional engineers quality Kart racing products. Our cables and accessories are well-engineered and designed for rigours of Motorsport. Aim Technologies racing components, are amongst the best in the industry today.
