Super B Andrena 12V15Ah-SC Lithium Race Car Battery
£633
Super B Andrena 12V15P-SC Motorsport Lithium Race Car Battery Lightweight & high performance lithium power battery developed for...
Lightweight & high performance lithium power battery developed for motorsports.
Key Features:
  • Nominal Capacity - 15Ah
  • Nominal Voltage - 12.8V
  • Dimension (LxWxH) - 249 x 96 x 141mm / 9.80" x 3.78" x 5.55"
  • Open circuit voltage - 13.2V
Lithium Motorsport Battery
Light-weight, high-performance, safe and reliable lithium power battery especially developed for motorsports. This battery equals a lead-acid battery of 40 to 60Ah provided the alternator's maximum current doesn't exceed the battery's maximum charge current of 52A. Designed in a standard rally casing. Suitable for 12V systems and for use in extreme environments.
Electrical Specifications:
  • Nominal capacity
15Ah
13.2V
  • Self-discharge
<3% per month
  • Cycle life
>1000 ( at 10c discharge, 100% DoD)
  • EqPb (Equals lead acid battery)
40 to 60Ah
  • Voltage
12V
Safe and Reliable
Super B batteries are based on lithium iron phosphate technology (LiFeP04). This is the safest lithium technology around today. With bespoke casing and electronics adding to the safety and durability. The battery is completely dust tight and waterproof, so can be used in the most extreme environment.
Mechanical Specifications:
  • Dimensions (LxWxH)249 x 96 x 141mm / 9.80" x 3.78" x 5.55"
  • Weight2.9 kg / 6.4Ibs
  • Case materialPC ABS
  • Ingress protectionCylindrical - LiFeP04
  • Cell type / ChemistryCylindrical - LiFeP04
Charge & Discharge:
  • Charge methodCCCV
  • Charge voltage14.3V - 14.6V
  • Max.charge current52A
  • End of discharge voltage8V
  • Discharge current continuous240A
  • Discharge pulse current708A (47C) (1 sec)
Temperature Specifications:
  • Charge temperature0°C to 45°C / 32°F to 131°F
  • Discharge temperature-20°C to 55°C / -4°F to 131°F
  • Storage temperature-20°C to 45°C / -4°F to 113°F
Compliance Specifications:
  • CertificationsCE, UN 38,3, UL 1642 (Cells)
  • Shipping classificationUN 3480
