Super B Andrena 12V20Ah Motorsport Lithium Race Car Battery
£688
Super B Andrena 12V20Ah Motorsport Lithium Race Car Battery Lightweight & high performance lithium power battery developed for...
Lightweight & high performance lithium power battery developed for motorsports.
Key Features:
  • Nominal Capacity - 20Ah
  • Nominal Voltage - 12.8V
  • Dimension (LxWxH) - 120 x 82 x 238mm / 4.72" x 3.23" x 9.37"
  • Open circuit voltage - 13.2V
Lithium Motorsport Battery
Light-weight, high-performance, safe and reliable lithium power battery especially developed for motorsports. This battery equals a lead-acid battery of 70 to 100Ah provided the alternator's maximum current doesn't exceed the battery's maximum charge current of 66A. Designed in a standard rally casing. Suitable for 12V systems and for use in extreme environments.
Electrical Specifications:
  • Nominal capacity20Ah
  • Open circuit voltage13.2V
  • Self-discharge3% per month
  • Cycle life1000 ( at 10C discharge, 100% DoD)
  • EqPb (Equals lead acid battery)70 to 100Ah
  • Voltage12V
Safe and Reliable
Super B batteries are based on lithium iron phosphate technology (LiFeP04). This is the safest lithium technology around today. With bespoke casing and electronics adding to the safety and durability. The battery is completely dust tight and waterproof, so can be used in the most extreme environment.
Mechanical Specifications:
  • Dimensions (LxWxH)120 x 82 x 238mm / 4.72" x 3.32" x 9.37"
  • Weight3.2 kg / 7.0Ibs
  • Case materialPC ABS
  • Ingress protectionIP69
  • Cell type / ChemistryCylindrical  - LiFeP04
Charge & Discharge:
  • Charge methodCCCV
  • Charge voltage14.3V - 14.6V
  • Max.charge current66A
  • End of discharge voltage8V
  • Discharge current continuous320A
  • Discharge pulse current892A (45C) (1 sec)
Temperature Specifications:
  • Charge temperature0°C to 45°C / 32°F to 131°F
  • Discharge temperature-20°C to 55°C / -4°F to 131°F
  • Storage temperature-20°C to 45°C / -4°F to 113°F
Compliance Specifications:
  • CertificationsCE, UN 38,3, UL 1642 (Cells)
  • Shipping classificationUN 3480
Super B Batteries Product Video
