Super B Mason 12V20Ah Lithium Race Car Battery
£810
Super B Mason 12V20Ah Lithium Race Car Battery Lightweight & high performance lithium battery designed for race cars for use in...
Lightweight & high performance lithium battery designed for race cars for use in extreme environments.
Key Features:
  • Nominal Capacity - 20Ah
  • Nominal Voltage - 12.8V
  • Dimension (LxWxH) - 255 x 101 x 171mm / 10.0 x 4.0" x 6.7"
  • Open circuit voltage - 13.2V
The new Mason 12V20Ah power battery is a light weight compact and offers high performance. Thanks to its lithium iron phosphate technology (LiFeP04) and integrated BMS system this new generation lithium battery is extremely reliable and offers optimal safety. The Mason serves as a voltage source for starting combustion engines, which use a 12V board net.
Electrical Specifications:
  • Nominal capacity > 20Ah
  • Open circuit voltag> 13.2V
  • Self-discharge3% per month
  • Cycle life >1000 ( at 10c discharge, 100% DoD) >1000 ( at 10c discharge, 100% DoD)
  • EqPb (Equals lead acid battery) > 70 to 100Ah
  • Voltage12V
Safe and Reliable
Super B batteries are based on lithium iron phosphate technology (LiFeP04). This is the safest lithium technology around today. With bespoke casing and electronics adding to the safety and durability. The battery is completely dust tight and waterproof, so can be used in the most extreme environment.
Mechanical Specifications:
  • Dimensions (LxWxH) > 255 x 101 x 171mm / 10.0" x 4.0" x 6.7"
  • Weight > 4.6kg / 10..1Ibs
  • Case materialPC ABS
  • Ingress protectionIP69
  • Cell type / ChemistryCylindrical  - LiFeP04
Charge & Discharge:
  • Charge methodCCCV
  • Charge voltage14.3V - 14.6V
  • Max.charge current > 66A
  • End of discharge voltage8V
  • Discharge current
    continuous > 260A
  • Discharge pulse current > 892A (45C) (1 sec)
Temperature Specifications:
  • Charge temperature0°C to 45°C / 32°F to 131°F
  • Discharge temperature-20°C to 55°C / -4°F to 131°F
  • Storage temperature-20°C to 45°C / -4°F to 113°F
Compliance Specifications:
  • CertificationsCE, UN 38,3, UL 1642 (Cells)
  • Shipping classificationUN 3480
Super B Batteries Product Video
