Super B Nomia 12V100Ah Lithium Traction Battery
£1,333
Super B Nomia 12V100Ah Lithium Battery A Unique combination of state of the art technology and smart software....
Key Features:
  • Nominal Capacity - 100Ah
  • Nominal Voltage - 12.8V
  • Dimension (LxWxH) - 417 x 227 x 314mm / 16.4" x 8.9" x 12.4"
  • Open circuit voltage - 13.2V
Lithium Battery
The Nomia 12V100Ah is a Lithium Iron Phosphate battery (LiFeP040) with a rated capacity of 100Ah. The unique combination of state of the art technology and smart software makes this lithium battery a robust, safe and easy to use energy storage solution. Compared to conventional lead-acid batteries. The Nomia is weight and space saving also very efficient and offers an extremely high performance and is maintenance free.
Electrical Specifications:
  • Nominal capacity > 100Ah
  • Open circuit voltag> 13.2V
  • Self-discharge3% per month
  • Cycle life >1000 ( at 10c discharge, 100% DoD) >12000 ( at 1C discharge, 100% DoD)
  • Voltage > 12V
Safe and Reliable
Super B batteries are based on Lithium Iron Phosphate technology (LiFePO4). This is the safest Lithium technology available on the market today. With bespoke casing and electronics further increase the safety and durability.
Mechanical Specifications:
  • Dimensions (LxWxH) > 417 x 227 x 314mm / 16.4" x 8.9" x 12.4"
  • Weight > 18.5 kg / 40.8 Ibs
  • Case material > GFRP
  • Ingress protectionIP50
  • Cell type / Chemistry > Prismatic - LiFePO4
Charge & Discharge:
  • Charge methodCCCV
  • Charge voltage14.3V - 14.6V
  • Max.charge current100A
  • End of discharge voltage8V
  • Discharge current
    continuous > 300A
  • Discharge pulse current > 500A  (10sec)
Temperature Specifications:
  • Charge temperature0°C to 45°C / 32°F to 131°F
  • Discharge temperature-10°C to 55°C / -14°F to 131°F
  • Storage temperature-20°C to 45°C / -4°F to 113°F
Compliance Specifications:
  • CertificationsCE, FCC, UN 38.3 UN ECE R10.05, EN/IEC 62620
  • Shipping classificationUN 3480
Super B Batteries Product Video
