Suzuki GSX-R 600, 750, 1000 ECU EVO4S Plug & Play Cable with 7 Pin Male 712 Connector
£50
Suzuki GSX-R ECU EVO4S Plug & Play Cable. The Suzuki ECU Interface cable is a specific cable which...
The Suzuki ECU Interface cable is a specific cable which allows easy installation and connection of the AiM EVO4S data logger to the bike ECU.
Key Features:
  • ECU Interface Cable
  • Simple Wiring
  • Receive Data
  • 7 Pin
  • 712 Male Connector
  • Free race studio 3 download
Suzuki ECU Plug & Play Cable Available For:
  • Suzuki GSX-R600 - 2006-2019
  • Suzuki GSX-R750 - 2006-2019
  • Suzuki GSX-R1000 - 2005-2019
  • GSX-R1300 Hayabusa Gen.2 - 2008-2016
Examples of Protocols Below
RPM, Throttle position, Engaged gear, Neutral sensor, Front wheel speed, Rear wheel speed, Engine coolant temperature, Selected map, Engine check, Manual throttle, Intake air temperature, Yawing rate, Rolling rate, Horizontal accelerometer, Vertical accelerometer, Longitudinal acceleration, Traction control intervention, Clutch switch, Side stand, Front brake, Rear brake, Oil pressure switch.
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster.
Not Enough Check Out Our Solo 2 DL & SmartyCams
    • Suzuki GSX-R 600, 750, 1000 ECU EVO4S Plug & Play Cable with 7 Pin Male 712 Connector
