Suzuki GSX-R 600, 750, 1000 Solo 2 DL Plug & Play Cable with 7 Pin Male Connector & Bracket
SKU:
SUZ-PP - SUZ-B - V0256914CS - V02569140
£85.00
Suzuki GSX-R Connector Kit
The AiM Suzuki GSX-R 600, 750, 1000 connector kit males it easy to connect the Solo 2 DL to your bike ECU.
Key Features:
Installation Brackets available for:
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster. |
Not Enough Check Out Our Solo 2 DL & SmartyCams |
Unlock your potential |
- Suzuki Plug & Play Cable
- 1 Bracket
- 1 Allen screw with rounded head M8X45mm
- 2 Allen screws with flat head M4X10mm
- 1 Toothed washer
- 1 Rubber dowel
