Triumph OBDII Plug & Play Cable.
The Triumph uses a OBDII plug placed under the bike seat, and allows easy installation to the AiM Solo 2 DL.
Key Features:
These models feature a standard diagnostic protocol based K-Line, accessible through the OBDII plug placed under the bike seat. For installation refer to the tech sheet. |
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster. |
Not Enough Check Out Our Solo 2 DL & SmartyCams |
Triumph Daytona, Street Triple & Speed Triple Solo 2 DL Plug & Play Cable with 7 Pin Male 712 Connector.
- Triumph Daytona, Street Triple & Speed Triple Solo 2 DL Plug & Play Cable with 7 Pin Male 712 Connector
