Tyre Pressure Monitoring System
£350.00
The tyre pressure monitoring system is the ultimate tool for alerting drivers to change in tyre pressures, aswell as providing data on how the tyre pressure alters throughout your races.
Compatible with our dash loggers Mange multiple wheelsets
Connection for CAN output Suitable for Motorsport
The tyre pressure monitoring system (TPMS) provides a method of displaying or logging real-time tyre pressures on our AiM dash/loggers (except solo 2).
The TPSM has been designed to withstand the rigours of Motorsport and is the ultimate tool for alerting drivers to a change in tyre pressures as well as providing a log of how the tyre pressures alter throughout your races.
This kit is compatible with competition and race car applications. This kit is supplied with an updated receiver and loom which connects to the car wiring and 4 lightweight sensors.
AiM Dashes and Loggers will require a CAN Protocol which can be obtained from AiM Technologies to interface with the unit.
Please Note: The Tyre Pressure Monitoring System can be used with all of our dash loggers (Except SOLO 2).
TPMS Receiver
The receiver is pre-coded with the four sensors that will use it.
Each sensor is labelled FR, FL, RR, RL for each on the wheels.
The TPMS CAN receiver is compatible with race applications and competitions. The receiver utilises 1 Mbit CAN that has become the standard overtime for professional ECUs, data loggers and dashboards within the motorsport and automotive sectors.
The receiver is allocated with unique identification serial numbers to ensure that only sensors with these serial numbers can be read. Any number of additional sensors can be programmed with serial numbers to make them compatible with the specific receiver.
The TPMS receiver comes supplied with a wiring harness to connect the receiver to your vehicles wiring. You can also connect the receiver directly to a car's wiring. The 6 way AMP connector on the redundant harness can be removed and reused on the car wiring.
Extra wheels can be clone coded, these can then be used as sets of spares for pit changes. (Handheld programmer required)
The receiver is supplied with a wiring harness to connect to your cars wiring.
TPMS Sensors
The TPMS sensors are already pre-assigned FR, FL, RR, RL, so all you need to do is connect the sensors to the correct tyre and all the data will be recorded on the receiver and than overlayed on tp your dash/logger.
Please Note: Should you wish to purchase extra sensors you will need to purchase the Handheld programming Unit. This will enable you manually programme the sensors.
The TPMS Handset (sold separately) is used for directly reading the sensor parameters such as pressure, temperature and battery voltage. It can also be used to programme or modify the sensor paprmeters like team code and wheel location.
  • Sensor pressure range: 0-8000mbar
  • High-frequency mode: FSK
  • Sensor temperature range: -40°C to 125°C
  • Sensor temperature resolution: 1C
  • Sealing: IP67
  • Battery lifespan: >2.5 million transmissions
  • RF frequency: 433.92MHz
  • High frequency emission power: <8dBm (50ohms)
  • Receiver Pinout:
  • PIN 1 RED - Supply 9-16V
  • PIN 2 WHITE - Screen
  • PIN 3 BLACK - GND
  • PIN 4 GREEN - CAN-
  • PIN 5 YELLOW - CAN+
  • PIN 6 N/C
  • Wire: 0.35mm/12/0.20
  • Cable Length: 300mm
  • Connector: AMP Superseal 6 way socket
  • Mating Connector: AMP Superseal 6 way plug
  • Four , Eight , Twelve Sensors depending on which option selected at checkout
  • One Receiver
  • One Loom
