FREE Shipping NEXT DAY Delivery Call +44 (0)1782 393843 Shop now, pay later
Aim TTPMS System with 4 Sensors
£2,680.00
The Aim Wireless TTPMS, Tyre Temperature and Pressure Monitoring System uses ultra-wide 16-channel infrared sensors and high resolution 24-bit pressure transducers for performance and safety.
In the Box:
  • 1x CAN Receiver
  • 4x Wheel Sensors (Additional Options of 8x or 12x)
  • 4x Wheel Valve Kits (Additional Options of 8x or 12x)
     Aim Technologies wireless Tyre Temperature and Pressure Monitoring System (TTPMS) consists of small, lightweight, wheel-mounted sensors and an equally small receiver with a built-in pressure transducer for high-accuracy gauge pressure measurements.
    The wireless sensor measures the lateral temperature distribution of the inner tyre carcass with an ultra-wide 16-channel infrared sensor and pressure with a high resolution 24-bit pressure transducer, providing invaluable tyre data for Motorsport and R&D applications.
    SPECIFICATIONS – TTPMS SENSOR
    • Pressure, Range (Gauge): 0 to 5000 mBar
    • Pressure, Resolution: 1 mBar
    • Pressure, FS Accuracy (typ): ±10 mBar
    • Internal Temperature, Range: -40 to 150˚C
    • Internal Temperature, Resolution: 0.1˚C
    • Internal Temperature, FS Accuracy: ±1.0˚C
    • IR Temperature, Range: -20 to 300˚C
    • IR Temperature, Resolution: 0.1˚C
    • IR Temperature, Accuracy (typ): ±3.0˚C
    • Sampling Period at Speed: 1.2 seconds
    • Operating Temperature Range*: 0 to 135˚C
    • Battery Life (typ): 1.5 million transmissions
    • Encryption: AES-128
    • RF Frequency: 868, 915, 920 MHz
    • RF Output Power: 1Mw
    • Wireless Range, Open Space: > 100m
    *Will survive brief temperature excursions < 150˚C
      SPECIFICATIONS – RECEIVER
      • Voltage Input: 5 to 16 V
      • Supply Current: 30 mA
      • Temperature Range: -20 to 85˚C
      • Max No. of Sensors: 120 (30 / corner)
      • RF Frequency, Centre: 915 MHz (adjustable)
      • Sensitivity (typ): -110dBm
      MECHANICAL SPECS – SENSOR
      • Weight: 21 ± 1g
      • Material: 7075-T6
      • Max. Centrifugal Accel: 2000G (SF = 3)
      •  L x W x H (max): 44 x 32 x 18 mm
      • Protection Rating: IP61
      MECHANICAL SPECS – RECEIVER
      • Weight: 18 ± 1g
      • Material: 6061-T6
      • L x W x H: (max) 50.5 x 35.5 x 8 mm
      • Protection Rating: IP65
      TPMS reciever
       CAN SPECIFICATIONS – RECEIVER
       Standard  CAN 2.0A, ISO-11898
       Bit Rate
       1 Mbit/s (configurable)
       Byte Order Big-Endian / Motorola
       Data Conversion
       1 integer per bit
       SN, TC, Node ID
         1 dBm per bit  RSSI
         1mV per bit  Battery Voltage
         1 mBar per bit  Pressure
       0.1˚C per bit, -100˚C offset
       (all variables unsigned except  RSSI)
       Temperature
       Base CAN ID (default)  1030 (Dec) / 0x406 (Hex)
       Termination  None
       WIRING SPECS – RECEIVER
       Wire  M22759/32-26, DR25
       Cable Length  500 mm
       Connector None
       Supply Voltage, Vs
      Red
       Ground Black
       CAN + Blue
       CAN - White
       CAN MESSAGE STRUCTURE – RECEIVER
       CAN ID: 0x406 (LF) / 0x40C (RF) / 0x412 (LR) / 0x418 (RR)
       Serial Number  Battery Voltage  Pressure  Gauge Pressure
       Byte 0 (MSB) Byte 1 (LSB) Byte 2 (MSB Byte 3 (LSB Byte 4 (MSB) Byte 5 (LSB) Byte 6 (MSB) Byte 7 (LSB)
       CAN ID: 0x407 (LF) / 0x40D (RF) / 0x413 (LR) / 0x419 (RR)
       Reserved (unused)  Reserved (unused)  Reserved (unused)  Reserved (unused)
       Byte 0 (MSB) Byte 1 (LSB) Byte 2 (MSB) Byte 3 (LSB) Byte 4 (MSB) Byte 5 (LSB) Byte 6 (MSB) Byte 7 (LSB
       CAN ID: 0x408 (LF) / 0x40E (RF) / 0x414 (LR) / 0x41A (RR)
       Byte 0 (MSB) Byte 1 (LSB) Byte 2 (MSB) Byte 3 (LSB) Byte 4 (MSB) Byte 5 (LSB) Byte 6 (MSB) Byte 7 (LSB)
       CAN ID: 0x409 (LF) / 0x40F (RF) / 0x415 (LR) / 0x41B (RR)
       CAN ID: 0x40A (LF) / 0x410 (RF) / 0x416 (LR) / 0x41C (RR)
       CAN ID: 0x40B (LF) / 0x411 (RF) / 0x417 (LR) / 0x41D (RR)
       Transmission Count  RSSI  Sensor Temperature  Sensor Node ID
      * The base CAN ID (0x406) is adjustable
      BASE CAN ID PROGRAMMING – RECEIVER:
      To modify the wireless receiver’s base CAN ID, sensor assignment mode, or bit rate, send the following CAN message at 1Hz for at least 10 seconds and then reset the receiver by disconnecting power for 5 seconds. For more details and options, refer to the Appendix.
       Programming Constant  New CAN Base ID (11-bit)  Sensor Assignment  Bit Rate
        Byte 0 (MSB) Byte 1 (LSB) Byte 2 (MSB) Byte 3 (LSB) Byte 4 Byte 5 Byte 6 Byte 7
       30000 = 0x7530 1 = 0x001
      2047 = 0x7FF
      1 = Default
      2 = Custom
      1 = 1 Mbit/s
      2 = 500 kbit/s
      3 = 250 kbit/s
      4 = 100 kbit/s
      CAN messages should only be sent to the receiver during the configuration sequence. DO NOT continuously send CAN messages to the receiver.
      DIMENSIONS:
       TTPMS
      RECEIVER DIMENSIONS:
      120° Field of View, Spatial Mapping of Temperature Channels Standoff Distance - (Distance from sensor to tyre(mm))
      120 Field of View
      *CAD model available with temperature channel rays*
       TRANSMISSION RATE
       State Criteria Data Update Period
       Uninflated or Cold
      Pgauge < 250mBar
      Tsensor < 5˚C
      None N/A (sleeping)
       Inflated Pgauge > 250mBar Pressure 240 seconds
       Inflated & Heated Pgauge > 250mBar
      Tsensor > 40˚C
      Pressure 10 seconds
       Inflated & ΔP Pgauge > 250mBar
      ΔPgauge > 10mBar
      Pressure, infrared 1.2 seconds*
       Rotation Wheel movement Pressure, infrared 1.2 seconds*
       * 10 second overrun before switching to lower state / longer update period
      SYSTEM LAYOUT
      Place receiver near centre of car, in cockpit, with antenna perpendicular to any metal or carbon-fibre surface. Most applications will only require one receiver, but a chassis with difficult RF penetration may require two receivers (front and rear).
      SYSTEM LAYOUT
      TYRE CORNER ASSIGNMENT – TTPMS SENSOR:
      By default, each TTPMS sensor is assigned to a specific corner/tire with a unique Node ID:
      • LF Node ID’s: 001 to 030
      • RF Node ID’s: 031 to 060
      • LR Node ID’s: 061 to 090
      • RR Node ID’s: 091 to 120
      The corner assignment for each Node ID is adjustable; refer to the Appendix for details.
      - Each team/set will be assigned a receiver with a unique Network ID and AES-128 encryption, therefore, protecting data between teams and cars.
      - The receiver will acquire data from all active TTPMS sensors in the pits but will only receive data from the fitted, active tires when away from the pits.
      ADDITIONAL INFORMATION:
      • Battery life depends on a multitude of operating conditions but will typically exceed 1 million transmissions (347 track hours) or up to approximately 3 years
      • The TTPMS sensor is fitted with a serviceable battery.
      • The maximum recommended sensor temperature is 120˚C for utmost reliability and battery life, but transient temperature excursions up to 150˚C are survivable.
      • To avoid dropped packets, the average Received Signal Strength Indication (RSSI) should be no less than -90dBm.
      • Two receivers may be used when signal strength is too weak with one receiver.
      • Do not wash the TTPMS sensors – keep dry.
      • Do not repeatedly remove and reinstall the sensor & valve assembly.
      PART NUMBERS:
      Part No. Description
      • TTPMS-V2 TTPMS Sensor
        W-REC-V2 TTPMS Receiver
        AV-ASC-U TTPMS Sensor Valve
      APPENDIX A.1 – BASIC RECEIVER PROGRAMMING:
      To modify the wireless receiver’s base CAN ID, sensor assignment mode, bit rate, or emissivity, send the following CAN message at 1Hz for at least 10 seconds and then reset the receiver by disconnecting power for 5 seconds.
       Programming Constant New CAN Base ID (11-bit) Sensor Assignment Bit Rate Emissivity
      2047 = 0x7FF
      1 = Default
      2 = Custom
      1 = 1 Mbit/s
      2 = 500 kbit/s
      3 = 250 kbit/s
      4 = 100 kbit/s
      1 = Default
      2 = Custom
      A.2 – ADVANCED EMISSIVITY ADJUSTMENT:
      Long-wave infrared radiation attenuates with increasing optical distance / standoff distance, increasing pressure, and changes with gas mixtures. The effective emissivity for each infrared temperature channel is adjustable in order to compensate for attenuation and, therefore, achieve utmost temperature accuracy when necessary.
      • The effective emissivity decreases with increasing optical distance, as quantified in the sample chart below. As shown in the sample model, the first couple infrared temperature channels have much longer optical distances than the other channels; therefore, the effective emissivity will be lower for the first couple channels in order to compensate for the longer optical distance
      • The effective emissivity decreases with increasing pressure, as shown in the sample chart below for air (low humidity). The sensitivity to pressure will depend on the gas mixture but is typically significant in one bar increments.
      • This behaviour is inherent for all infrared radiometry measurements, not just this sensor.
      Example: Pressure = 2 bar, T1Optical Length = 270mm, T12Optical Length = 100mm
      εT1 ≈ -0.00039 x 270mm + 0.82 ≈ 0.71, εT12 ≈ -0.00039 x 100mm + 0.82 ≈ 0.78 .
      CAN MESSAGE for PROGRAMMING EMISSIVITY:
      “Emissivity” (Byte 5 in Section A.1) must be set to “Custom” (i.e., Byte 5 = 2) in order to activate custom emissivity assignments.
      CAN ID = Base ID (Default = 0x406)
       Programming Constant ε, T1 ε, T2 ε, T3 ε, T4 ε, T5 ε, T6
       Byte 0 (MSB) Byte 1 (LSB) Byte 2 Byte 3 Byte 4 Byte 5 Byte 6 Byte 7
      20030 = 0x4E3E = LF
      20040 = 0x4E48 = RF
      20050 = 0x4E52 = LR
      20060 = 0x4E5C = RR
      .01 = 0x01
      1.0 = 0x64
      .01 = 0x01
      1.0 = 0x64
      .01 = 0x01
      1.00 = 0x64
      .01 = 0x01
      1.00 = 0x64
      .01 = 0x01
      1.00 = 0x64
      .01 = 0x01
      1.00 = 0x64
       Programming Constant ε, T7 ε, T8 ε, T9 ε, T10 ε, T11 ε, T12
      20031 = 0x4E3F = LF
      20041 = 0x4E49 = RF
      20051 = 0x4E53 = LR
      20061 = 0x4E5D = RR
      .01 = 0x01
      1.0 = 0x64
      .01 = 0x01
      1.0 = 0x64
      .01 = 0x01
      1.00 = 0x64
      .01 = 0x01
      1.00 = 0x64
      .01 = 0x01
      1.00 = 0x64
      .01 = 0x01
      1.00 = 0x64
       Programming Constant ε, T13 ε, T14 ε, T15 ε, T16 ε, Default
      20030 = 0x4E3E = LF
      20040 = 0x4E48 = RF
      20050 = 0x4E52 = LR
      20060 = 0x4E5C = RR
      .01 = 0x01
      1.0 = 0x64
      .01 = 0x01
      1.0 = 0x64
      .01 = 0x01
      1.00 = 0x64
      .01 = 0x01
      1.00 = 0x64
      .76 = 0x4C
      DO NOT
      CHANGE
      A.2 – CUSTOM CORNER ASSIGNMENT OF TTPMS SENSOR NODE ID’s:
      Each sensor is assigned a unique Node ID; the receiver may be programmed to assign any Node ID to any of the four wheels (LF, RF, LR, or RR).
      “Sensor Assignment” (Byte 4 in CAN message above) must be set to “Custom” (i.e., Byte 4 = 2) in order to activate custom corner assignments.
      CAN MESSAGE for PROGRAMMING NODE ID ASSIGNMENTS:
       Programming Constant ID - 1 ID - 2 ID - 3 ID - 4 ID - 5 ID - 6
       20000 = 0x4E20 = LF
       20002 = 0x4E22 = RF
       20004 = 0x4E24 = LR
       20006 = 0x4E26 = RR
      0 = 0x00
      120 = 0x78
      0 = 0x00
      120 = 0x78
      0 = 0x00
      120 = 0x78
      0 = 0x00
      120 = 0x78
      0 = 0x00
      120 = 0x78
      0 = 0x00
      120 = 0x78
       Programming Constant ID - 7 ID - 8 ID - 9 ID - 10 ID - 11 ID - 12
       20001 = 0x4E21 = LF
       20003 = 0x4E23 = RF
       20005 = 0x4E25 = LR
       20007 = 0x4E27 = RR
      0 = 0x00
      120 = 0x78
      0 = 0x00
      120 = 0x78
      0 = 0x00
      120 = 0x78
      0 = 0x00
      120 = 0x78
      0 = 0x00
      120 = 0x78
      0 = 0x00
      120 = 0x78
      A.3 – FILTERING SELECTED CORNER TTPMS SENSORS:
      The receiver may be programmed to only receive data from selected corners (e.g., LF and RF wheel TTPMS sensors). - When using multiple receivers on the same CAN Bus, they must be programmed individually.
      CAN MESSAGE for PROGRAMMING CORNER ASSIGNMENTS:
        Programming Constant LF Sensors RF Sensors LR Sensors RR Sensors
       20010 = 0x4E2A
      1 = Enabled
      2 = Disabled
      1 = Enabled
      2 = Disabled
      1 = Enabled
      2 = Disabled
      1 = Enabled
      2 = Disabled
      0 = 0x00 0 = 0x00
      A.4 – RECEIVER NETWORK, NODE ID, and RF FREQUENCY:
      - The receiver’s Network, Node ID, and Radio Frequency (from 868 to 920MHz) may be changed in order to communicate with another set of TTPMS sensors.
      - Each team is assigned a unique AES-128 encryption key, so sensors may only be used with different receivers within the same team.
      CAN MESSAGE for PROGRAMMING NETWORK, NODE ID and RF FREQUENCY
       Programming Constant Network ID Node ID Radio Frequency
       20020 = 0x4E34
      0 = 0x00
      255 = 0xFF
      0 = 0x00
      255 = 0xFF
      Decimal Value x 105 Hz
      (ex: 9155 = 915,500,000 Hz)
      0 = 0x00 0 = 0x00
