Universal Dash Display Steering Wheel Bracket – Aim Shop - Motorsport Data Loggers, Displays and Laptimers
SKU: UP-UM
Availability: 20 in stock
£10.80
QTY:
Trust Badge
Universal Dash Display Steering Wheel Mount. Our interchangeable stainless steel steering wheel button and display mounts are a very stylish and cost effective solution to your mounting requirements. The whole design is based around the centre hub which mounts between your steering wheel and (usually) your quick release device.
**Please note that if you have a low or no 'dish' steering wheel, you will probably need the 3mm hub spacer to give sufficient bolt head clearance**
The hub is made to suit 70mm PCD and 74mm PCD 6 hole steering wheels. This covers almost all of the 6 hole market. We have a range of bolt on items to then connect to this hub including a range of left, right or bottom button sets.
