SAME-DAY DISPATCH
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Yamaha R1 2004-2008/R6 2006-2013 SoloDL Cable & Bracket
£85
The Yamaha R1 2004-2008/R6 2006-2013 Solo DL Cable & Bracket makes it easy to connect the Aim Solo 2 DL to your Yamaha bike ECU.
This is a cable and bracket  to connects the Aim Solo DL to the Yamaha R1 Motorcycle.
Part number     V02569190
On Race Studio 2 select:
ECU Manufacturer:     YAMAHA
ECU Model:
  • BIKE_R6_06_10     (R6 2006-2013)
  • BIKE_R1_04_05_06     (R1 2004-2006)
  • BIKE_R1_07_08     (R1 2007-2008)
Technical drawing:
Part number     X46KSYR16
The bracket can be used with Solo and SoloDL.
In the box:
1  bracket, 2 distance pieces,
2  M6 self-locking nut,
4  M6 washers,
2  M4 self locking nuts,
2  M4 washers,
2  4x10 Allen screws with countersunk head,
2  6x60 pan head Allen screws.
Download the installation manual
User manual
