NEXT DAY DELIVERY
on orders before 3pm
FINANCE AVAILABLE
on selected products
FIRST-CLASS SUPPORT
Yamaha R1 2009-2013 Solo 2 DL Cable and Bracket
£85
The Yamaha R1 2009-2013 Solo 2 DL Cable and Bracket makes it easy to connect the Aim Solo 2 DL to your Yamaha bike ECU.
This cable and bracket is used to connect the Yamaha R1 2009-2013 to the Aim SoloDL Laptimer.
Cable:
Part number: V02569210
On Race Studio 2 select:
ECU Manufacturer:     YAMAHA
ECU Model:     BIKE_R1_09_11
Technical drawing:
Bracket
Part number     X46KSYR16
The bracket can be used with Solo and SoloDL.
In the box:
1x  bracket,
2x  distance pieces,
2x  M6 self-locking nut,
4x  M6 washers,
2x  M4 self locking nuts,
2x  M4 washers,
2x  4x10 Allen screws with countersunk head,
2x  6x60 pan head Allen screws.
Download the installation manual
Download user manual
