AiM Solo 2 DL with Plug & Play kit for Yamaha the most precise way to get lap times.
Key Features:
Connecting to over 1,000+ ECUs we are sure it will work for you.
Solo 2 DL now features a digital input allowing to log RPM either from square wave signals (8-50V each signal) or pulse signals (150-450v) ignition coli trigger-primary circuit. |
Solo 2 DL gives instant Speed, Timing, Splits live data and predictive lap times.
Solo 2 DL screen can be back lit in one of seven available colours.
The Solo 2 DL has 10 configurable RGB LEDs, and will give you a clear and fast indication of the comparison with your last lap. Predictive page: shows the predicted current lap time in the format you set. |
Solo 2 DL can manage two types of data or races: |
Make it even better and add Multiple cameras to your Solo 2 DL
With wifi connectivity you can transfer your data securely and quickly to your laptop or computer without cables. |
- Display - Graphical
- Display resolution - 238x00 pixels
- Display pages - Up to 5 freely configurable
- Back light - 7 configurable RGB colours
- Shift lights / alarm LEDs - 10 configurable RGB LEDs
- Integrated track database - Yes
- Intertial platform - Internal 3 axis +5G accelerometer + 3 axis gyro + 3 axis magnetometer
- Wi-Fi connection - Yes
- GPS - 10Hz
- External power - 12 V
- Memory - 4 GB
- Battery type - Rechargeable Lithium
- Push buttons - Metallic
- Dimensions - 98.0x73.7x30.2 mm
- Weight - 240g battery included
- Waterproof - IP67
- ECU connection - CAN, RS232 or K-Line to 1,000+ industry leading
- Aim Solo DL 2 Motorcycle Lap Timer
- Power cable with AC adapter
- User manual
- Aim sticker
- Yamaha Cable
- Yamaha Bracket
