Yamaha YZF-R1 EVO4S ECU Plug & Play Cable.
The Yamaha ECU Interface cable is a specific cable which allows easy installation and connection of the AiM EVO4S data logger to the bike ECU.
Key Features:
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster. |
Not Enough Check Out Our Solo 2 DL & SmartyCams |
Yamaha YZF-R1 2009-2014 (YEC included) EVO4S ECU Cable with 7 Pin Male 712 Connector
- Yamaha YZF-R1 2009-2014 (YEC included) EVO4S ECU Cable with 7 Pin Male 712 Connector
