Yamaha YZF-R6 2004-2005 Solo 2 DL Plug & Play Cable with 7 Pin Male Connector & Bracket
SKU:
YAM-4-PP - YAM-4 B - V02569200 - X46KSYR16
£85.00
Yamaha YZF-R6 Connector Kit
The AiM Yamaha YZF-R6 connector kit makes it easy to connect the Solo 2 DL to your bike ECU.
Key Features:
Please Note: For this model/year AiM recommends not to remove the stock dash. Doing so will disable some of the bike functions or safety controls. AiM will not be held responsible for any consequences that may result from the replacement of the original instrumentation cluster. |
Not Enough Check Out Our Solo 2 DL & SmartyCams |
Unlock your potential |
- Yamaha plug & play cable
- 1 bracket
- 2 spacers
- 2 self-locking nuts M6
- 4 washers M6
- 2 self-locking nuts M4
- 2 washers M4
- 2 allen screws with flat head M4x10mm
- 2 allen screws with rounded head M6x60mm
