With the Aim GS-Dash & EVO4S Powerboat Racing Data Logger Kit, it's not just about collecting data. it’s about understanding and applying it where it matters most- on the water.
In this article we will cover what the kit is, its key features and also why no professional should have to go without one.
What Is The Aim Powerboat Racing Data Logger Kit?
The Aim GS-Dash & EVO4S Powerboat Racing Data Logger Kit is a product that brings high-level performance tracking and analysis to the marine racing world. With a setup designed to withstand the harsh conditions of water racing and deliver crystal-clear feedback, this system allows competitive racers to extract actionable insights from every lap.
Combining the crisp visibility of the GS-Dash display with the intelligent logging power of the EVO4S, the kit gives you a complete overview of your boat’s behaviour- both in real-time and in post-race reviews.
What Are The Key Features Of The Aim Powerboat Racing Data Logger Kit?
Every powerboat racer should know the importance of having good quality equipment for championships, events or even just practices, and with the Aim Powerboat Racing Data Logger Kit that is a guarantee. Alongside state-of-the-art tech, it is packed with specifically catered features for anyone. From beginner to advanced, it is made just for you. Every feature is outstanding; however, a few should be specifically noted.
- Compact 4.3" LCD display with 7 configurable colours makes critical data easy to read in all lighting conditions, so you never miss a beat mid-race.
- 5 RGB shift lights and 4 LED alarms can be fully customised to show RPM thresholds and system alerts exactly when you need them.
- EVO4S logger supports CAN, RS232, and K-Line ECU connections along with analogue and digital inputs, allowing you to integrate virtually any sensor into your logging setup.
- Built-in 3-axis accelerometer and gyroscope capture fine detail about your boat’s movement and handling for better post-session analysis.
- IP65-rated aluminium housing keeps your equipment protected from water spray and vibration, ensuring durability in demanding race conditions.
How Do The Aim GS-Dash & EVO4S Work Together?
In the unpredictable environment of powerboat racing, reliable data can mean the difference between a good lap and a great one. The GS-Dash offers intuitive visibility of the metrics that matter most- speed, RPM, water temperature, fuel pressure, and more- all easily accessible without distracting from the race itself.
Meanwhile, the EVO4S logger works quietly in the background, collecting an immense range of inputs to give you a full picture of your vessel’s performance. From ECU parameters to G-force and handling data, everything is captured with precision.
How Can The Aim Powerboat Racing Data Logger Kit Help You?
With accurate insights delivered in real time, you’ll know when to push, when to adjust, and how to outpace the competition. This system isn't just for post-race debriefs- it actively supports better decisions on the fly and smarter setup tweaks between heats. Whether you're racing at the national level or refining your edge for club events, this system is built to help you improve with every lap.
The Aim GS-Dash & EVO4S Powerboat Racing Kit gives you more than data - it gives you clarity, confidence, and control.
At Aim, we pride ourselves on our impeccable services and our effective products. Want your racing life to be made simple? Get yours here today and let your data do the talking with the Aim GS-Dash & EVO4S Powerboat Racing Kit.
