Gå till produktinformation
1 av 4
Aim Brake Pressure Sensor Dash 3 3/8 24 0-160 Bar Motorcycle
SKU: S-P-B-D3-160-X05PSA00160B38-MC
Vanligt pris
£190.00
Vanligt pris
Försäljningspris
£190.00
AiM Brake Pressure Sensor Dash 3 3/8 24 0-160 Bar
The AiM 3/8th 24 0-160 Bar pressure sensor is suitable for oil and fuel pressure readings and can read pressures up to 160 bars. This sensor will monitor brake pressure levels for optimum performance accurately.
3/8th 24 -  0-160 Bar 4 pins 719 male binder
The AIM 3/8 24 0-160 bar brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers.
  • Supply: 8-16V
  • Characterisation: 500 mV/ 0 bar 4500 mV/ 160 bar
  • Consumption: < 10 mA
  • Sealing: IP66
  • Weight: 30g
  • Cable Length: 400mm
  • Thread: 3/8th 24
  • AiM Brake Pressure Sensor 3/8th 24 - 0-160 Bar
The AIM 3/8 24 0-160 bar brake pressure sensors are fitted with male four pins black 719 binder plug connections to suit all AIM loggers and dash display/loggers. Whether your bike is equipped with single, dual, fixed or adjustable master cylinders, adding brake pressure sensors allow you to monitor brake performance, make fundamental changes and identify issues quickly and precisely.
  • Supply: 8-16V
  • Sealing: IP66
  • Weight: 30g
  • Thread: 3/8th 24
